Not sure if its heat or a poor clock, but my 5670 gets to about 79/81 deg and the machine hangs.. From what i read thats abuot the thermal limit. Would the heat cause it to freeze or is it more likely to be a bad clock?
mines bottling out at 3.4 . got my ram low (1333) to rule that out . not sure about uncore ratios . voltage is 1.28 which I think is high enough .
... And ECC ram they can be overclocked too. Just look for Hynix ECC 8gb/stick ram, they are really cheap, only around 10-12 pounds/4GB.
Are people having success with Gigabyte X58A-UD3R rev 1.0? I see one person here has, but elsewhere I'm seeing lots of people saying it's not working. :S
Hello, new to the forum.
Love these (cheap) Xeon's, running 4.4Ghz 24/7 now. With temps up to 81.
To be honest, I haven't tried to push it further since the temp is a bit high. My 360 rad is a bit thin, thinking replacing it with a thicker one 45mm+ maybe?
Love this forum btw, regards from Norway![]()
I have one running bios F8a, working fine with a Xeon X5670.
Currently have it @4.2Ghz on 1.34v.
You don't even have to install any drivers.Will i need to reinstall windows or will I be ok swapping the cpu?
How much thermal paste goes on these ? still a cooked grain of rice in the center?
