Don't know if I already mentioned, but found your guide very helpful.
So thanks a lot, as generally helped me grasping an understanding in some more headphones.
That's nice to hear, thank you for reading.
I would say if you want that more lush sound it would be worth doing. You seem to love your HD650's so I can't see it being a negative. The K712 foams are a bit more dense feeling as well and it seems to give a more fuller low end so if you can get the foams that specifically come with the current 712 they would help.
If you use your 702's for gaming I'd leave them as close I stock as possible though.
Some new gear coming.
AKG K501 arrived waiting for me at home!
Another HD650
Little Dot MKiii plus mullard tubes and other tubes!
Ever heard the D7000? Looking to buy some
The K501 I'm finding to be on a similar level to the HD600 series when it comes to ability. They are incredibly airy and light, I need to try them in DH mode to see if the staging expands like crazy like the K701. The mids are stunning, they are not overly forward and intimate like I usually like but they have such a realistic voicing to them.
Vocals sound so pure and clean it's really something vocal fans need to hear. Instruments sound crisp and realistic too. They don't have the bass I usually want but it's extended enough to not get put off. To be honest the mids are so good, I just don't care I've got other bassey headphones to fill that role but I still find them snappy enough for pretty much anything personally.
Compared to the HD650 they are not as romantic and dreamy sounding but they are more pure and musical. They make a great pair actually! The vocals sound more intimate and mellow with the Senns but the K501's sound like real life. I like the HD650's better overall slightly but I think the K 501 have special mids that give the closest life performance feeling yet.
I'm keeping these for sure, they are a classic and it's nice to own something so rare that sounds amazing.
