- 24 Sep 2013
Yeah, but I don't understand what 'depth of field' on or off actually means or what is does.
What is the practical difference. I was trying to see the difference last night and I couldn't really tell. In the end I think I liked it better with the setting 'off' but not sure why (I know the PS3 version didn't have depth of field).
it puts blur on foreground/distance depended where you are looking
The depth of field will allow the screen to focus on something the foreground, while blurring the background. So if you have it turned on, and look closely at a car, everything but the car (should) blur out a bit.
It is the same effect that a lot of mods do on PC (ENB mods normally), to make the game look more realistic.
e: beaten like a ginger step child![]()
I haven't played this version of GTA but usually depth of field simply means things at a distance are out of focus. If it is static then all things in the distance will be blurry and up close sharp. If it is dynamic then usually it changes depending on what you are aiming at. Try aiming at something close and keep an eye on object in the distance they should blur.
Edit: beaten like a ginger conjoined twin.
Yep^^^we covered it pretty well
not my pics grabbed them from the social club
