- 25 Nov 2011
- The KOP
Will there be a performance difference between the 2 considering one is done on the gpu and the other via the gsync box?
AMD say yes, Nvidia users say No...
We must wait and see..
AMD admit that the gpu doing all the work will have a negative effect on framerates?AMD say yes, Nvidia users say No...
No!
The last benefit is essential to gamers, as Project FreeSync does not need to poll or wait on the display in order to determine when it’s safe to send the next frame to the monitor.
Project FreeSync uses industry-standard DisplayPort Adaptive-Sync protocols to pre-negotiate supported min/max refresh rates during plug’n’play, which means frame presentation to the user will never be delayed or impaired by time-consuming two-way handshakes.
How this shows we must wait and see! CSGO would be a good start...
Maybe I should linked you.
http://support.amd.com/en-us/search/faq/220
Nowhere in that does it say thay gsync DOES have to wait on polling or wait on the display, you are just assuming that as it is listed as a benefit of adaptive sync that it is a benefit OVER gsync, but to me it reads exactly as a benefit over vsync, as polling and waiting are how vsync works
How is Project FreeSync different from NVIDIA G-Sync? said:There are three(3) key advantages Project FreeSync holds over G-Sync: (1)no licensing fees for adoption, (2)no expensive or proprietary hardware modules, (3)and no communication overhead.
(4) - wait, wut??)The last benefit is essential to gamers, as Project FreeSync does not need to poll or wait on the display in order to determine when it’s safe to send the next frame to the monitor.
In response to that...
I shall use the quote above you![]()
Edit:
Its more AMD marketing though so i'll take it with a pinch of salt.
And why I said we will after wait and see.. But given how poor Gsync is with CSGO I would like to see that as one of the games benched...
Very interesting..
What is "after wait and see"?
I see you play CS:GO a fair chunk, so you will have to give us your feedback on it when you get a Free-Sync monitor. Gladly, I am not a CS:GO player and don't have to put up with how poor it is on nVidia or do the fix that sorts it out that you have been told about numerous times.
I will say again though, if Free-Sync is as good as G-Sync (that I have been using for months and thoroughly tested), you guys are in for a real treat![]()
Once again, the fact remains that Adaptive-Sync capable monitors will be developed by third parties and the learning curve will be high the first time around. While I am certain they will be significantly cheaper than any G-Sync powered counterparts, I am also pretty sure these FreeSync capable UHD monitors will have a premium over Non-FreeSync capable units. The pricing on the UD590 (Non-FreeSync) is around $600, so you are looking at a price range upwards of $600 for a FreeSync capable 4K display.
Read more: http://wccftech.com/amd-freesync-capable-monitors-revealed-future-compute-event/#ixzz3JjPJzeoF
OMG< OMG the last benefit is talking about 3 not adding in 4..
Simply Stunning![]()
I thought you had no interest in this technology shanks?
Or has this view changed now AMD are close to having a offering.
Shank's - 1
Tone - 0
The difference must be huge though, for AMD to make a point about it. Good few Ms difference?
0.02ms wasn't it?
