- 17 Aug 2012
- Tamworth, UK
Check my guide.
Check my guide.
Reaper can you help me with something?
I went through your guide step by step and stumbled across a problem..
The stutter fix mod requires you to edit the ENBlocal.ini file and add the stutter fix DLL file as a proxy... but this wont work with Serentiy END as this not only has the d3d.dll file from the ENB files but also a sweetfx Dll file included in the end file..
So have you yet tried the stutter fix + serentiy enb? as you would end up with 3 dll files in your skyrim folder but only able to load 2
Got my Gigabyte GTX 970 G1 and overclocked to 1569/2000, it's just incredible! No frame rate drops in Skyrim and temps are great!
However I might try this
Yes, that Verdant grass look s like the final piece of the puzzle. Always hated the patchy grass look.
Cant believe I spent a whole week off work playing this and still never got round to playing the main quest.
- I spend most of my time hunting and crafting lately, using the hunting mod and tweaking values and such make's it great source of EXP and money if done properly.
Looks lovely but I bet its gonna be FPS genocide like most grass mods![]()
did you have to do anything to get the hunting mod working?
Killed some animals last night and didnt see any options... I have immersive creatures installed so maybe conflicting with that?
I really must play this game.. I swear i have put hundreds of hours into modding but never actually played it.
Anyone know how Skyrim + ENB handles AMD Xfire? I'm probably gonna buy a 2nd 280x in the new year.
Dammit i am so jelly of those screenshots neil. I hope father christmas brings me a nice big SSD and make game run better.
It still stutters on occasion, just loading up big new areas, other than that smooth as! SSD makes a big difference, more so the CPU clock and GPU
