Caporegime
- 30 Jul 2013
Crossfire does not work at the moment. There is a profile but AMD decided to disable it for whatever reason.
So does crossfire work in fc4 as my understanding was there is no profile for it yet.
The AMD CrossFire profile for Far Cry 4 is currently disabled in this driver while AMD works with Ubisoft to investigate an issue where AMD CrossFire configurations are not performing as intended. An update is expected on this issue in the near future through an updated game patch or an AMD driver posting.
It works for me now too.Works fine for me.
Ram leak issue still there i presume?
Not sure, my task manager wasn't showing any signs of leakage.
As far as i know, the Mantle system memory leak has been fixed. I just tested it now for 25 minutes and no issues and my system memory usage climbed from 3.5gb to 3.8gb. Mantle is a 64 bit application so it's normal to see more system memory usage. In fact, I'll go as far to say that it's the best it's ever been right now in Battlefield 4. Stunning!![]()
Brill!! What us this stunning btw??
Indeed BF4 is running the best it has ever been with Mantle, DX is running good as well though.
I think the problem for AMD users is Mantle runs so well that it makes DX look bad in comparison when actually DX runs ok, just not as well as Mantle. I have to say though once you start throwing two, three and four gpu's into the mix (even at 4K) the difference between Mantle and DX is huge.
System can sometimes hang when upgrading to Catalyst™ 14.11.2 from Catalyst™14.7 in AMD CrossFire™ configurations. As a workaround please completely uninstall previous Catalyst™ software versions before installing Catalyst™14.11.2 beta.
: Slight performance drops in FIFA 2015 on AMD CrossFire™ configurations.
: Occasional flickering sometimes observed while playing FIFA 2015 in AMD Dual Graphics configurations.
: Slight Battlefield 4 performance drop on AMD Radeon™ R9 290X in AMD CrossFire™ configuration.
: AMD Radeon™ R9 285 intermittently hangs in Hitman Absolution on new game start.
: AMD Radeon™ R9 285 can sometimes exhibit flickering in Assassins Creed Unity.
: Assassins Creed Unity can sometimes experience frame stutter on some AMD CrossFire™ configurations.
: Call of Duty: Advanced Warfare intermittent black screen when loading game in Quad AMD Crossfire™ configurations.
: Civilization: Beyond Earth mantle users in AMD CrossFire™ configurations may sometimes experience an issue where they cannot change their game resolution. As a work around please use "Enable MGPU=1" in the games configuration .ini file.
AMD is currently working with BioWare to resolve the following issues:
Flickering is sometimes observed in Dragon Age: Inquisition on a limited number of surfaces in AMD CrossFire™ configurations.
AMD is currently working with Ubisoft to resolve the following issues:
Uneven hair corruption sometimes observed in Assassins Creed Unity when applying "ultra" game settings.
Flickering occasionally observed between windows on walls in Assassins Creed Unity.
Windows/Doors intermittently flash with black textures in Assassins Creed Unity.
Assassins Creed Unity occasionally exits to desktop when "ultra" game settings are applied.
