- 19 Jun 2012
Exceeding the railings?
DAS IST VERBOTEN!!!
In your opinion, yes.
If it aint broke, don't fix it?![]()
I'm not saying the quality is bad (I wouldn't know) but the quantity....
I don't even read that much for my university course, let alone cs:go![]()
Oh, there is a lot to be fixed. One way smokes, jumps (jump scout), CZ, Nuke/Overpass being CT sided as hell, server issues, MM issues, some invisible walls/glitches in overpass, overpass just needs more work in general, amongst the hundreds of other problems cs:go has.
I went for the Logitech G400s, since it's supposed to be the same as shame as an MX518 but better. Need to send the zowie back when it arrives!
Put a bet on mouz as they have good odds against C9, bet on IBP too but didn't put too much on as VP are my guys! Pasha is too funny.
My Friend.
ive bet on VP. not great returns but a return is a return.
mouz is a good shout i think.
what time are the matches?
Yes, it is the same form factor, just with a better optical sensor. Great mouse really, but Logitech build quality has fallen through the floor in recent years, unfortunately
I have used the same form factor for years, but the final straw was when I bought a G400 and it only lasted 6 months before I got the dreaded cable break.
Decided there and then I wouldn't buy another, because the 518 I had replaced also only lasted a year or so, whereas previous ones had lasted years.
Cracking mouse mate, but dont be surprised if you get cable break a lot sooner than older Logitechs.
Anyone use a mouse bungee? Supposed to make a world of difference, not having the cable dragging on desk with movement, or catching on the back of the desk.
I recently got a Roccat Kone XTD. Couldn't recommend it enough. However, this best thing I can recommend is a soft gaming mat. The one I'm using is a Roccat Taito and it's made my game 10x better.
Team vote-kicked him after the fourth round, but the people on the opposing team were still complaining about it. They were lucky they came across people who didn't want an easy win otherwise they would've lost very badly, can't please some people![]()
I use a SteelSeries Heavy pad b.t.w.
In your opinion, yes.![]()
Mine as well, no one reads forum dissertations
Roccat Kone..For those that want a colourful mouse, not a good mouse. Jittery ass sensor
