- 19 Feb 2010
- Nottingham
Depending on the model, it's going to have a temp sensor and fan headers also.
Ok, not that much then over the regular version.
and also via aquabus 3-pin to the HIGH aqaubus header on my 5XT
The 3-pin cable came with the Aquaero I believe (I got both the XT and the flow meter together, can't remember which came with which exactly).
From what I've read the 4-pin Aquabus cable is essentially the same as the 3-pin, except it has a power cable as well. If you use this then you can remove the USB cable, once it's set up.
The most worrying thing for me is that is doesn't change at all, even by .001. So either the reading really is constant or there's something wrong with the unit!
I don't have and 4-pins to hand but I'll buy one now and see if it makes any difference.
So I've installed the flow sensor (Aqua Computer High-Flow USB) but I think it's possibly borked.. either that or I'm confused..
The reading is constant, no matter what situation the system is in - not even a slight variance as you might expect.
What I've done so far:
- I've connected the device to USB so it appears in aquasuite on the left, and also via aquabus 3-pin to the HIGH aqaubus header on my 5XT.
- I've checked that the device does appear on the "Currently connected aquabus devices" list, as well as on the "flow sensors" list
- I've configured the device as "Flow sensor high flow USB" on the MPS config.
However, the reading is "stuck" on 2.313 l/m
I don't have a vario pump so I can't instigate a change, but I'd expect some change in the lower decimals at least?
Squeeze the tube while it's on and the flow rate should drop, when I do that to mine the flow rate graph on my Aquaero 5 shows the drop.
Will give the new firmware a try shortly- thanks for the heads up!
It looks like one of its main new features it support for a new aquacomputer product called farbwerk - It's an RGB LED Controller.
Interesting as there was a chap on their forums who was making these for end users - Allowed you to hook up a LED Strip to an aquaero controller which I was looking to get imported from him. Cost was pretty high though (came to about £50). These are cheaper at a reported RRP of about £30.
More info here: http://forum.aquacomputer.de/weiter...color-in-your-life-new-4x-rgb-led-controller/
Any OCUK staff members confirm when its going to be available please?
But then Aquacomputer themselves developed it and banned the sales of Jeak Amp
I myself have bought 3 Jeak RGB Amps from Jeak and I would always recommend Jeak RGB Amp over this farbwerk.
I think I've bought mine at around £10 each PCB.
link: http://forum.aquacomputer.de/berwachung-und-steuerung/102291-jeak-rgb-amp/
Yeah they'r a bit cheeky that way - he should have copyrighted it or somat
The cost of the module was pretty cheap - it was the cost of shipping which ramped up the charges considerably unfortunately as he was in Germany.
More like 21EUR.
