Well thought i'd give you guys an update
My KFL clone arrived yesterday it came with a coil and wick pre installed it's a very big tank system and is very weighty which is nice!
But!!!!
after priming it i still got dry hit's!!!
i turned the voltage right down to the minimum on the MVP2 and even after 2 or 3 vapes i still get them.
Can any one help?
I did order some pre made coils and a jet lighter to burn them off (FYI i didn't torch the pre installed coil other than dry burning it with no liquid on it 3-4 times didn't see any hot spots so figured it would be ok?)
So i'm going to wait till the new coils come and give it another try also whats the other screw hole for? ones for air flow which i worked out but the other one didn't seem to do anything? i even took the screw out and no liquid came out so im guessing it's not a fill port?
On a positive note i decided to order some new e liquid to go with my new KFL 3.1 clone i went with vampire vapes ( im a sucker for bright packaging!)
I got a 4 pack of flavours Heisenburg , Pinkman, Bat Juice and Funky monkey
They only came this morning so i popped Pinkman in an iclear i30s and it's an amazing fruity flavour tastes like Vimto/Slush puppy definately my new vape for awhile!
