Dripping (DD; direct dripping)- Vaping by adding a few drops of e liquid directly into the atomizer chamber instead of using a cartridge. This is the method that gives the best vapor quantity and flavor quality.
This, for example, is a dripper.
Hmm, so it does or doesn't hold a certain amount of eliquid in it and it wicks it like usual, instead you put drops of liquid on it every time you want to vape or something and keep doing it every puff? confused much haha!
Yeah. I tend to chain vape a fair bit and I usuall have to refill the KFL say, every 24 hours or so-ish.
Wow I use around 1 1/2 tanks on my KFL per day.
I am on 3ml nic though, still not good.
What's the best stuff to get for a starter?
Maybe I don't chain vape as much as I thought
Was using 11mg though.
Currently using 6mg in the dripper and it's a bit too much tbh. Gonna have to drop to 3mg and it's looking like I'll be making my own juice from next week.
Depends on whether you know vaping is for you really and how much you're prepared to spend.
I started straight away with a Kayfun and a Vamo V5, not having ever vaped previously. Was sick of ciggies and just wanted to get on with it.
Most people start with an IGO type vape pen for around £20 or less.
lol
What does he use?
Haha, I fill my Kayfun every hour or less, a 5000mah battery lasts me 2 hrs just a 18650, I vape 6mg, I use hmm, about 50ml of eliquid per day, I used to smoke a 50g pouch of tobacco every 2 and a half days though
Jesus!
I thought I was terrible getting through 50g every 4 days...
As for 50ml a day and filling every hour... Wow. I don't even know how that's possible.
Hehe, I smoke cheap eliquid though hangsen, I get it off the bay 1 pound for 10ml. well, maybe I was a bit ott, I used 38ml of liquid yesterday.
I used to use 20-30ml in my old protank 2 mini, used to have to fill it up all time cause it only held 2ml or so, but I liked it because you could make new coil bases for it, would just make a bunch and then just keep them stored ready just swap and away ya go, with the kayfun you gotta drain it, take it apart etc rather than just coil swapping, id use a coil per day on the protank 2 mini, this kayfun i used 5 days with 30g kanthal but well Iv just rebuilt my coil now that i made yesterday, past two days iv been using new 28g kanthal first time using 28g I used 30g before, first hour or so with new coil is twice as good as 30g but then after that its just gone absolutely black has the coil so this time iv blow torched the wire etc first to see if it was just some gunk on the wire and iv used less cotton than I usually do, so lets see how it gets on I guess
