Just to be sure of what you mean.
I.e note down the values for the xmp profile and enter the timings and voltage in to the bios in manual mode?
Correct.
cache/uncore is at 4600mhz_1.24v(bios)_1.26v(windows)Very nice resultsWhat uncore speed are you running?
Also what are your other voltages set at? Vrin, ring voltage and system agent and i/o analogue and digital volts
1.35v on air for 24/7 use. But do not stress test with p95/ibt etc. The temps will hit insanely high levels.
You weren't joking. Tested IBT first and temps rocketed to 85c, so killed that quick. Running Asus Real Bench now and it's holding steady at 65c. That's stock and pulling 1.175v. Will try an overclock later once this is done and I'm happy it's not going to go any further in temps.
for prime95 u need a custom water loop..![]()
In that case you may want to check this:
NH-U9S
NH-9DL
Small 90 coolers _ check their specs!
Was Haswell-E getting a bit boring stulid![]()
I think platform maturity has a lot to do with it.
The Z97 SOC Force just loves to clock.
