- 23 Jan 2007
- Wakefield
Thanks DataVampire, I thought as much but I'd check as the 5's are on offer everywhere.
Thanks I already knew this. all my fans are added to a curve, as I said was fine before I updated to the new aquasuite 2015 lol
Did you redo all your curves DV?
I took this as an opportunity to re-do them, but forgot at first about minimum power adjustments for the fans. I was seeing my fans stay off for longer than they should. Switched that back (think it was 22%ish for mine) and now working again as before.
is this the correct cable for connecting my pump,flow meter and rez to the aquaero ? Aqua Computer aquabus Y-Cable 4pin 53124.
