- 17 Aug 2012
- Tamworth, UK
What level are you, things like that trigger after level 8.
.. Wasn't planning on joining them but then stumbled upon one of those gems and got curious what it was for..
Just bought this for £2.50 in the Steam sale lol crazy price
Thinking about purchasing an upgrade to my GTX460 but I don't game enough these days to warrant buying anything brand new and top end.
I want to enjoy Skyrim in all its glory though and was looking at some videos with the ENB mods and it looks great.
Do you think a GTX660 (2nd hand) will be sufficient along with an i5 2500k at 4.5ghz to run this at 1080p with an acceptable framerate? Or would I have to sacrifice some of the high gfx settings?
Witcher 3 is on the horizon also which I really want to play, I don't mind toning the settings down a little I just don't want to buy an inadequate card that isn't going to be much of an improvement over my MSI GTX460 Talon.
Thanks in advance
Not to 'scare' you but SLI 780Ti's can just about cope with skyrim with a good enb with all the bells on, and maintain 60fps.
This is at 1440p or 2560 x 1080 which are my monitors. Normal 1080 will be kinder, but not a huge amount. ENB needs serious grunt unless you go for a lite one. It's worth it though, I'm totally mad on enb skyrim.
Framerates still dip occasionally but only in weird CPU bound places.
. However I'm very happy, and I'll be looking to get another Gigabyte G1 970 next year
I have SLI 680's and run Skyrim @ 60fps (including all the mods in my guide + an ENB).
A single 780/780ti should handle it all fine.
@String, what mods do you have installed? You should be in the high 90-100's at least.
Are you using nvidia inspector, as that can help a lot with SLI.
How about when looking at the main arch/entry to Riverwood with full SMIM on the go?
Just me?
Just me?
