Thinking about buying another R9 290x oc card but wondering if ! will my I5 2500k cope with it ok ? looking at 4k gaming. cheers.
Also Can I pair my MSI R9 290X OC edition With the MSI R9 290x LE VERSION ? Is that possible
How are you finding Mantle Tom?
What does LE mean ? As can't find any info on the web any where about it !
I take it the LE just means not overclocked ? and if you wanted to you could overclock it to 1080 mhz ?
Whoopsy. I've just ordered a 290X Vapor-X (peasant 4GB) to Crossfire with my Windforce bought one year ago. My finger slipped multiple times and Mastercard let it happen.
I just wanted to share my excitemen... erm... news of this tragedy
Just praying my Corsair AX760 will be sufficient (with overclocked 4770K)?
My PC decided to switch itself off after approximately two hours of playing Sniper Elite III. It refused to boot back up until I had disconnected one of my 290Xs. I had thought I was cutting it fine to Crossfire with 760W but I think I just confirmed it... new PSU required?
Computer boots up as normal with one card disconnected.
Does that sound like a correct diagnosis?
It could be as SEV3 uses a lot of power and produces a lot of heat on the cards.
Having said that check to see that your case is not getting too hot.
The cards were certainly hot to touch. To be more specific the game was crashing with Mantle when looking towards the stormy sky above a fort. The shutdown happened when I switched to DirectX and played on a little further...
Isn't Crossfire borked in Sniper Elite III with Mantle, it only using one card?
So possibly when you switched to DirectX both cards were in use and the power drain became to much.
Just downloading SEV3 to test out Mantle CF but I think it is still broke.
We will have to pester the Red Baron (AMDMatt) next time he posts to get on the case.![]()
It's not up to AMD to provide Crossfire support in Mantle titles unfortunately, that's not how the low level API works. All performance optimisations must come from the developer - and this includes adding support for multiple graphics cards. I'm afraid i don't know when it will be added and given the time of year, i would not expect anything in the near future.
What i can say is using DirectX works very well in Crossfire in this title, the scaling is immense. Currently playing it in Quad Crossfire at 4K maximum settings and it looks fabulous with x4 Supersampling enabled too.
If you use 3-4 graphics cards i recommend ditching the stock Crossfire profile and using 1x1 Optimize instead. Using this profile at 4K maximum settings will put you a long, long way ahead of any other graphics card multi gpu combination from any vendor.
I completely forgot memory clock scales with core voltage on the 290s. I was testing my memory at stock core volts and only got around 1525.
Seems to be running fine at 1650Mhz with max volts.
It crashes at 1700Mhz after about a minute of Heaven.
