I'd suggest the Aspire Nautilus mini but it only holds 0.5 ml more. Anything that holds more is going to look bad on the iStick. I really don't know what is what in pre-made coils any more so I'd wait for other to suggest things too.
This is what it looks like with a kanger aerotank v2, like the aspire there's a slight overhang on the button side of the device but it holds 2.5ml.
You should be able to use the same atomiser heads as your protank 2.
Oh the drip tip on it is non standard.
Glad you're happy with it bud, was the wrapping OK?
I tried to make it as protected as possible.
i fancy a new dripper, preferably one i can run in either dual or single coil. anyone have any recommendations? clones welcome![]()
Have a look at the Hobo... or the new marquis, I hear both are good, the Marquis is like a better version of the Vertex and comes with bars for doing your coils and placing them while you tighten down the leads.
I have one of each on order from FT, so not tried them myself yet, going to be at least 7 days before they ship.
The freakshow is only £17.99 and has been getting good reviews. Very good flavor and vapor.
I have broken, I am not ready to quit yet.
Had run out as of around 9pm - woke up this morning to WW3 between wife/rugrats. I reached for the vape much to my horror which wasn't there anymore.
Going out this morning to buy some juice from my local B&M, they stock Ruthless stuff, take it that is ok for Dripping? Might get myself a selection as for a B&M they are priced correctly.
Do you find the BD v2 just eats through a tank in no time? Pretty sure you can only get around 3ml in there.
Nice vape though. Convenient too when you can't be arsed to keep dripping![]()
