Images of items I have purchased.
Status
Not open for further replies.
Decided to treat myself...
Raymond's covered the pluses.
If you like using 3D then it's a definitely a good upgrade. The way it tracks your head, even in a dark room by using an infrared camera is amazing. There's none of this positioning your head at just the right distance and angle anymore.
The little rubber joystick is the C stick. For some games such as Smash Bros and Monster Hunter it's a must.
I went for the XL version myself and I'm finding it to be great!
The 3D tracking is amazing, I kinda got this one as I am a sucker - I have a XL but don't use it much and when i do it was with 3D off but on the new one the 3d is incredible as it is always in the right place!
I always found the original 3DS too small but the XL a bit big, the screen doesn't have the pixel count to match the size - this one seems about bang on so I hope i will get use from it even if it did come with plenty of sucker tax!
No doubt I will get a new XL, we have 2 atm....
How do you find using the pliers on that? Could use a new one myself as on my cheapy multi tool the blades and things are on the inside aswell as the plier jaws and it is a complete B**** trying to apply pressure when using the pliers as the handle cuts into my fingers.
How much did you spend for the R3 Survivor Edition? I got my close to release and it costed a bomb. As far as I know, there were a few created so I have a small feeling it will go up in price eventually, but last time I saw them go for 20 quid!
There is someone selling them on the bay for only £29. Brand new as well.
After getting rather disillusioned with football and visiting Boston,
Thought i would start following boston celtics and what nicer way than buying the anthem jacket
yeah it's fine can apply plenty of pressure using pliers no way it can cut or dig in to hands . very well made multi tool
Ah quite a nice upgrade then. I don't play my 3DS XL as much as I would like too so will probably wait a while to see if they come down a bit (will be waiting a while!).
But honestly, you can't tell me there's enough space on that little thing to mouse in a satisfactory manner, not unless all you're doing is some browsing and no gaming/editing etc :p
I bet your mouse DPI is set to something zany like 4000 just so the cursor goes from top to bottom on a 1080P screen with a few mm of movement!
Status
