.Sorry to tell you this but we all got these speeds on the day it was installed![]()
I can tell you now it will drop down to about 55 after a month or so .... Kinda sucks in away as you know you can get those speeds but BT don't let you keep that profile for long.
What did your line start out at? Out of context it's impossible to draw any conclusion from that![]()
Vectoring will sort it out. When it eventually arrives.
.Vectoring will sort it out. When it eventually arrives.
Can someone recommend me a replacement for my home hub 3? The thing is ******* me off eternally since getting a ps4, it randomly closes ports used by the ps4 (80 and 443 mainly) giving me major issues, tried every trick I can find, dmz, static ip, manual port forwarding with upnp both enabled and disabled. Basically pinned it down to the hh3 being complete ****.
Ideally looking to spend no more then £100, have two wired devices and around 5-7 wireless.
