- 17 Aug 2003
- Woburn Sand Dunes
Why?
Why? you're trying to take the **** because i'm 'defending nvidias costcutting'. Go look up how AMD make their lesser GPUs then get back to me; There's reason i said it was standard industry practice - because it is. You dont throw away an expensive 5.2billion transistor die just because 5% of it is faulty, you build in obsolescence and make the die viable for lesser, cheaper configurations. Thank goodness you have nothing to do with nVidia OR AMD.
Maybe not 1x GTX970 being able to run 4K, if ever you decided to add another in SLI for 4K. Or you played a game a game which can easily make use of more than 3.5GB of VRAM. i.e. Shadow of Mordor & DA:I
I dont do multi card, never will unless it's given to me on a plate. So yeah, get those mis-sold 970's on the MM already
