I would not have bought the card if I new of this issue...the specs had no mention of the .5gb section of the total 4gb....
I bought the card based on specs..I never bought into a gimped card...regardless of performance...I wanted an upgrade path...
I'm gaming at 1080p at the mo....so it's not an issue..the 970 flies and I love it...but this will not be the case after spending 600 plus on a 1440p panel in March...I want the best performance I can to run this monitor and I would not have bought a card in December with 3.5 gb of Ram and a slower 500mb section...![]()
They way dual card memory is speced on the box is exactly the same as the GTX 970, it is all there but no explanation is given to how it is used.
2gb but the card is not really suitable for anything other than 1080p
Surely you bought the card because of the performance, and what the reviews showed it could do. The specs are somewhat irrelevant compared to performance.
The performance is still the same, and reviewers would have done 1440/1600 benchmarks. I'm currently on 1440 and the 970 is fine, but i'm not foolish enough to crank settings too high as i want smooth gameplay.
I own a couple of these cards and I could argue that I have been misled by false advertising.
On the front of the box
It states that it has 2gb of VRAM
It does not state that it is a dual GPU card.
This means that if I am not tech savvy I could make the mistake of thinking I am buying a single GPU card with 2gb available to the core.
I could also miss the fact that CF is required to get the most out of both cores.
I could also buy a product that is totally unsuitable for the case I have because of the dual cores, this card uses more watts than a 290X.
As a non tech savvy consumer I find the front of the box totally misleading.
It should be about the performance.
nVidia get it wrong/lied in the tech specs to reviewers, then didnt correct it when the review came out or any time after that until these events.
These specs cause issues for some people, almost completely in relation to SLi. I've seen reports of single cards stuttering but it's always been in games that other cards struggle with as well. ie, not the best evidence.
whether the card has 64 rops or 56 or 32 makes no different to me - my card performs the same regardless. same as it did in the reviews which is why i bought it in the first place. all this stuff about nVidia lying, it's going too far.
All the info was there on release so your point is mute. The same can't be said for the gtx970.
Yep this is what i might do, but i'll probably get rid of it when the 390/390x's come. Won't be giving Nvidia money again any time soon.
....So where does it say on the front of the box that it is a dual GPU card as this is it's most important feature.
My point stands.![]()
Why does it bother you so much? People feel that they have been lied to and don't want it to happen again. They are voting with their wallet and returning the cards. It's a point of principle for these individuals not the performance.
It absolutely is for me as, unlike a lot of people in this thread, i actually own one.If you are happy with your card keep it, this thread isn't for you, it's for those people that aren't happy with the misreported specifications and the slow .5 GB of vram. For some people the first issue is the main reason for feeling hard done by, the second does affect sli configurations and could possibly affect single card situations in future.
