- 17 Aug 2012
- Tamworth, UK
Excellent that's what I'm currently running.
So I have it installed now, using the SFO LoD patch for the trees, and as the ENB suggests switched from Relighting Skyrim to ELFX.
Everything is very bright at the moment, so going to play around to get the settings right & then will post some screenshots.
FPS is tanked down for about 20 fps from 60.
Brightness I still can't find a fix for!
EDIT: I have a feeling the ENB is using my default .ini's and not the MO ones.
Have applied the ENB fixes to both files.
No Luck, it looks great but shadows are annoying me and the performance hit is insane!
Seasons of Skyrim:
T.A.Z Visual Overhaul: (So Far)
