This is the situation I am in, I specifically went 970 SLI because I wanted my rig to last as long as possible before my next upgrade. Had Nvidia been honest with me I would never have considered upgrading to 970 SLI and would have stuck with my GTX780 until Titan2/390X arrived
The way I see it I have the following options:
Urrgh, lol.
- RMA both cards and get a decent GTX960 or a used 680/770 to tide me over until the Titan2/390X hit.
- RMA both cards and put the 290 from my spare rig into the main one, and hope the noise doesn't cause me to throw the entire system out the window before the Titan2/390X hit.
- RMA both cards and get a beefy GTX980 or a used Titan Black and hope they last me a long while.
- RMA both cards and get GTX980 SLI.
- RMA one card and then run a single GTX970 as long as possible.
If I was you i'd RMA both cards and get your money back. As you already have a 290 and are only worried about the noise, shove that into your system and wait until the next gen.
However if you really don't want to go down the AMD route, grabd a 980 and be done with it.
