Cheers guys! I did a little googling last night after Ste gave me a few pointers and I noticed P6X58D users seem to set their uncore frequency exactly double that of their ram.
I did just that and was able to zip straight up to 200BCLK with no additional QPI VTT, I'm sure I could wind the QPI voltage back from 1.3v.
Now I just need to figure out how I can get my ram to post at its rated speed of 1600mhz.
DragonQ, this is the ram I'm using.....
http://www.gskill.com/en/product/f3-12800cl9t-12gbrl#tabs-spec
So these are the ram testing settings I was using last night.....
CPU Ratio Setting......................[12.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[133]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1603MHz]
UCLK Frequency.........................[3208Mhz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.2125]
CPU PLL Voltage........................[Auto]
QPI/DRAM Core Voltage..................[1.3]
IOH Voltage............................[Auto]
IOH PCIE Voltage.......................[Auto]
ICH Voltage............................[Auto]
ICH PCIE Voltage.......................[Auto]
DRAM Bus Voltage.......................[1.5]
I was hoping after lowering the UCLK frequency as discussed, the ram would play ball and post at its rated speed. Unfortunately it did not.
Any suggestions regards to the ram?
Thanks again for your help guys.
