- 2 Sep 2014
- West midlands
Can some one please tell why my post count has gone to 0?
Okay, mine is on +13 and you jumped straight to +60 surely that's a bit overkill?
Was you able to up the Memory voltage too?
Also what were your card temps like?
Been spamming?
Use Trixxx if you want up to +200mv, might want to set the fan at 100% though. User discretion is advised.![]()
I manually set my fans to 70 percent in msi afterburner, so they were running constant. When you up voltage it will allow you to up memory. if i had not have raised voltage to say 60 odd i would not have been able to add more memory as it needs the extra volts.
Start off small if your not sure about voltage and work your way up. get a stable gpu clock at +13 then increase when needed.
So want to use trixx to get more than the +100 on offer out of msi afterburner!
Whats a safe vddc matt?
Can you please define for me how i have been spamming?
There is no set in stone safe limit richard, so please use with caution. I'm sure others here can advise you better regarding this.![]()
I have a separate memory voltage though?
Yeah i got the core stable at 1120/1250 @ +13, i'll push the memory then add voltage.
I put my fans up to 100% noise doesn't bother me too much.
i'm guessing you had this also?
Generally going from thread to thread writing one word and not really contributing in general to the discussion in order to get the post count up for free shipping.
That is generally perceived as "Spamming" I am not saying you was doing that, just asking if you had been.
Please have a look at just this thread where on right now and tell me what you see, and look in my profile, also i have been on the forum since september but before that i had purchased from ocuk before and stuff purchased for me by my brother who has been with ocuk for years.
For me this is dodjy, i get to 245 posts then bam with no warning 0.
Send one of the Dons an email. It could just be a mistake bud![]()
On the main forum front page, at the right hand side is a list of moderators for each particular subforum. You can click on a name to contact one of the dons with any enquiries you have.I hope so, but how do i do that?
You have a different msi afterburner than mine, Did it come with the lightning? The lightning was specifically designed for overclocking so you might have more settings than me.
