New PCS+290 Arrived today plus some benchmarks
Okay, mine is on +13 and you jumped straight to +60 surely that's a bit overkill?
Was you able to up the Memory voltage too?
Also what were your card temps like?
I manually set my fans to 70 percent in msi afterburner, so they were running constant. When you up voltage it will allow you to up memory. if i had not have raised voltage to say 60 odd i would not have been able to add more memory as it needs the extra volts.
Start off small if your not sure about voltage and work your way up. get a stable gpu clock at +13 then increase when needed.
I have a separate memory voltage though?
Yeah i got the core stable at 1120/1250 @ +13, i'll push the memory then add voltage.
I put my fans up to 100% noise doesn't bother me too much.
i'm guessing you had this also?
Can you please define for me how i have been spamming?
Generally going from thread to thread writing one word and not really contributing in general to the discussion in order to get the post count up for free shipping.
That is generally perceived as "Spamming" I am not saying you was doing that, just asking if you had been.
You have a different msi afterburner than mine, Did it come with the lightning? The lightning was specifically designed for overclocking so you might have more settings than me.
Please have a look at just this thread where on right now and tell me what you see, and look in my profile, also i have been on the forum since september but before that i had purchased from ocuk before and stuff purchased for me by my brother who has been with ocuk for years.
For me this is dodjy, i get to 245 posts then bam with no warning 0.
Send one of the Dons an email. It could just be a mistake bud :)
I don't have a clue what it came with, i don't have a disk drive so didn't even look at the disks. I just downloaded it from the website
Man that Trixx software is buggy, everytime I click "settings" the program crashes(!)...
I managed to figure out the constant 3D clock thing, I had unofficial overclocking mode set to 'without powerplay support', once I disabled unofficial overclocking all is well and the card is now downclocking when idle with an overclock (yay) :)
Crazy score BTW richard, was 1600 faster than 1500 for you then?
I noticed a drop in performance with anything over about 1500.
EDIT: you can change the skin for AB in the 'User interface' Tab.
I'm considering a pair of these for crossfire. I've only got a one-slot gap though, do you think it overhangs too much into the third slot to allow for proper cooling?
Might need to fork out a bit more for Tri-x's.
