Sorry, I've not read the whole thread so it may have been asked already, but seeing as Maxwell is quite efficient I wondered what the chances are of us seeing a dual Maxwell card?
None what so ever as Nvidia have run out of letters in the alphabet
This might explain why the GK210 was released:
http://wccftech.com/nvidia-gm200-gpu-fp64-performance/
Now let’s get straight into it. According to the leaker Nvidia will launch a GeForce GTX card based on a cut down version of the GM200 GPU. The leaker didn’t specify the number of disabled SMMs or the name of the product. So we’ll assume that this will end up being the rumored GTX 980 Ti. Performance figures for a yet unreleased GTX 965/ 960 Ti have also been leaked.
Several benchmarks as well as a GPU block diagram of GM200 have been leaked.
AMD R9 390X, Nvidia GTX 980 Ti and Titan X Benchmarks Leaked – GTX 965/ 960 Ti Shows Up Too
Read more: http://wccftech.com/amd-r9-390x-nvidia-gtx-980ti-titanx-benchmarks/#ixzz3UKP4enSV
Not a chance
Look at the clockspeeds they chop and change and are very dodgy.
Any reason why the VRAM on a 6gb and 12gb card clock the same lol
And what are the clocks for a reference 295X2 again lol.
Clock speeds aren't static any, not quite sure how that is news to you. Boost clocks which change for any given game. There is also no reason why 6 and 12gb cards shouldn't have the same vram clocks.
I'm not saying they are real, but better reviews these days will quote a clock speed in a given game because it changes and that is an important thing buyers should know before buying if for no other reason than someone will buy a card look at clock speeds and wonder why it's running 30mhz lower than they expected.
http://www.anandtech.com/show/8526/nvidia-geforce-gtx-980-review
List the gtx 780 as 7Ghz as well.
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-980/specifications
Nvidia list it as 7Gb/s, OCUK have them almost all listed at 7010Mhz for whatever reason. I wouldn't nitpick over 10Mhz but that is just me.
as for underclocking, a 295x2's default clock is 947Mhz, it's boost clock is 1018Mhz. Driver issue, particular system, again 10Mhz is mostly nitpicking. If they were saying 400Mhz or 1200Mhz that would be one thing.
But we again seem to be in a situation that you are making some strange assumptions.
290x coolers aren't useless and again stock clocks aren't what you think they are, what they will boost too depends on the system. The cooling, where they are testing, driver set, maybe simply the application reading the clocks which could be rounding up or down.
Believe the numbers or not, but using inaccurate stock clocks to discount the clocks you see isn't a particular good reason to not believe them.
http://www.anandtech.com/show/7930/the-amd-radeon-r9-295x2-review/17
again as you can see here, in various games the 295x2 ran at different clocks.
