- 6 Jan 2013
- Rollergirl
I've done that. There's a little flap you can fix to if you drill it. I'll post a pic later.
snip
Does anyone have any recommendation on LED strips? Preferably cheap, dimmable and if possible colour change? Oh and it would help if they didn't burn down my house as well![]()
The nxzt led cables sound just about right for you,can be turn on or off aswell as having 3 adjustable brightness levels.
The 2m variant can be cleanly routed in the main compartment with only a few cm's of overlap.Nice bit of kit
I have seen some of these kits on Amazon/Ebay that have a big strip and you just cut and solder. They have a little remote too that changes the colour and brightness etc.***Project Logs Rules and Guidelines - Please Read Before Posting - IMAGE QUOTERS WILL BE BANNED***
Please read rule 10 as you should have done before posting.
Also note the thread title.
Cheers
Surveyor
Sweet build!
I just bought this case and wondered how tyou managed to fit fans at the bottom?
How many different fans in there![]()
Been working on a lil' build. Just waiting on a couple of small bits and then we're done.
Because I really liked this pic, here's a sneak peek until hopefully tomorrow, when I can show what happened to the actual case![]()
Barrow 16/13. You can find them at a certain auction site.
I'm pretty sure they're essentially rebranded Bitspower, so yeah
They feel like quality items with nice threads and orings etc fwiw.
