Corsair Carbide Air 540 Builds
Here's mine, still waiting for some CableMod cables to tidy it up a bit..
Here is my 540 :)
After seeing someone have their fan controller inside the case i decided to move mine too as i never actually change the speed of the fans.
I need to sort out the noctua's next they are really starting to annoy me colour wise.
Also has anyone ever managed to paint the colours of the fan Rings? I fancy trying one of the ones i dont use to see if i can spray it silver or something :)
Would that also fit on the top somewhere as well?
It was a build for someone else and I honestly never thought to try it on the top, as it had a H105 cooler in exhaust there, so didn't require a top filter really. It's about the right size for it, but may not fit perfectly. Hopefully if anyone buys it for the bottom, they can test it on the top first and let you know?
This one fitted perfectly:
YOUR BASKET
1 x Silverstone SST-FF142B Magnetic Fan Filter - 320x155mm £5.99
Total : £8.96 (includes shipping : £2.48).
Just had to use sticky tape on the four corners to hold it to the base. Not an issue.
Nice one,cheers man will get one ordered..........
....and i will update if it can fit the top.Although i think it might be a little big for,will find out tho :)
I can't comment on it being the best setup, but it works fine for me! I have all my fans on a fan controller set to around 700rpm, it's reasonably quiet.
So im installing my WC parts atm,and i have relised to do the tubing that i want my ODD bay has got to removed,this in itself doesnt bother me.But im plannin on getting a lamptron FC5 in the next week or two,and intend on using it in the ODD obv
Is does any one know of a ghetto method of do so without the ODD bay? Or will i have to change my tubing route if i want to use the a FC ?
