Corsair Carbide Air 540 Builds
Quick pics of mine now it's all built up. I'll post some more when I have more time and I'm not half asleep :)
Very nice that, Andy.
Thank you! I am pleased with it. It is a little noisier than I hoped (H105 pump I think mostly).
Pic of the dark side:
The fan controller on it's side in the front panel didn't play well with my OCD so in the back it went! It's pretty much set and forget anyway, I have the fans at around 700rpm and all my temps are very good.
So i built my Cube :D My camera is bit derp tho,as i may have recently dropped and semi broke my s4 mini lol
Using nzxt led cable for the lighting,in person its a dark shade of green,nowhere near as bright and obnoxious as it appears in the photo.Gpu sag is thankfully not quite as bad as it looks from that angle either
Had a rather annoying issue moving all parts tho,the PSU mount screws would not turn properly,i actually snapped a screwdriver trying to untighten them so i could move the bracket to accommodate my Leadex PSU.Was rather infuriating in all honesty,spent close to 40 mins trying to get them to loosen,ended up using a kictchen knife :confused:Still need to tidy a few of the cables down the bottom and the zip tie the GPU cables so it looks neater.
Very happy with the case overall tho.So now i can prepare for my CPU loop.
Im eyeing up a D5/xres combo, that CS tells me should be bak in stock in 2 weeks.Kinda wanna mount in it in the main chassis ,would it be possible to use the bracket and mount on it the central front 120mm fan slot? in this case between the two Enermax fans?
I also had another idea.I think it would be cool to find a way to mount in the ODD bays,and find a clear plexiglass 2 slot 5.25 cover.So that you could see the res from the front of the case.I know the ODD bay it self can be removed,it could even be possible to mount a pump where the bracket would normally mount.
Any one got any ideas/suggestions?
Does anyone with this case know if it's possible to add a 3.5" drive in the 5.25" bay with an adapter like THIS ONE? The fact this case only has x2 3.5 mounts at the bottom is somewhat annoying, as I'd want my SSD's on display there, and as I don't use optical drives I was thinking I could requisition the 5.25" bays for an HD or two. I see a lot of people doing the bungee mod, but is that because an adapter won't work?
Are you only adding one drive? If so, just screw it to the back of the case. Effortless!
Sorry about the image size...
** No spoiler tags in Project Logs **
Please re-size and post as I've done for you.
Cheers
Surveyor
The ODD bays are tooless,but those adaptors should work fine,as they are same dimensions of CD drives ect.Most people wouldnt use them tho as they would block access to the top vertical groments which would affect cable routing.
@MrMD I had trouble mounting an xspc photon170 D5 res/pump in the front of the case, it ended up going in the back above the PSU
I can see how it could be problematic to fit a 170 res in the front lol :D
Im thinking of only a 100/110m(mostly for ease of access to Fill ect) res myself,hopefully i can find a way to mount one that size in the front somehow.
All else fails it will go above the psu tho :)
They are custom cables i don't think i am aloud to mention who from but they make the difference when it comes to the finished look , the yellow on the gfx does spoil the theme but i will be water cooling at some point . picture below was before the cables
