Welcome Visiting Huawei  Home Gateway
Copyright by Huawei Technologies Co., Ltd.
Login:admin
Password:
ATP>sh
BusyBox v1.9.1 (2014-01-21 16:44:38 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Last initialization procedure status:   0
Max:    Upstream rate = 25977 Kbps, Downstream rate = 71720 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 70083 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        6.6             10.0
Attn(dB):        15.2            0.0
Pwr(dBm):        12.5            6.6
                        VDSL2 framing
                        Bearer 0
MSGc:           18              150
B:              239             236
M:              1               1
T:              22              5
R:              0               16
S:              0.1090          0.3771
L:              17616           5410
D:              1               1
I:              240             255
N:              240             255
                        Counters
                        Bearer 0
OHF:            48386775                567007
OHFErr:         867             0
RS:             0               3198944
RSCorr:         0               27
RSUnCorr:       0               0
                        Bearer 0
HEC:            1416            0
OCD:            44              0
LCD:            44              0
Total Cells:    3178330585              0
Data Cells:     429456234               0
Drop Cells:     0
Bit Errors:     0               0
ES:             608             0
SES:            14              0
UAS:            972             958
AS:             87359
                        Bearer 0
INP:            0.00            0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            1.80            6.15
OR:             106.34          202.87
AgR:            70189.82        20203.27
Bitswap:        60129/60129             32/33
Total time = 1 days 20 hours 23 min 27 sec
FEC:            0               27
CRC:            867             0
ES:             608             0
SES:            14              0
UAS:            972             958
LOS:            0               0
LOF:            13              0
LOM:            12              0
Latest 15 minutes time = 8 min 27 sec
FEC:            0               0
CRC:            3               0
ES:             3               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            0               0
CRC:            5               0
ES:             5               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 20 hours 23 min 27 sec
FEC:            0               26
CRC:            740             0
ES:             499             0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 24 hours 0 sec
FEC:            0               1
CRC:            127             0
ES:             108             0
SES:            14              0
UAS:            946             932
LOS:            0               0
LOF:            13              0
LOM:            12              0
Since Link time = 1 days 15 min 59 sec
FEC:            0               27
CRC:            867             0
ES:             591             0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
#And you should look at the documents in more detail yourself. I didnt say it wasnt based on the ITU specs, Im saying that there are likely modifications to the base ITU spec in order to meet compliance for BT interoperability, such as NICC ND1602 : Specification of the Access Network Frequency Plan (ANFP)
Applicable to Transmission Systems Used on the BT Access Network.
And if BT were the standard the UK should follow then Sky and Talk Talk as i said do not follow the same configurations. BT have nothing to do with any spec.If it was totally based on ITU then they wouldnt have their own specs for access to BT network.
Oh really... this is about to be funny againThe crux of the matter that you keep missing the point of, regardless whos fault it is that these issues have arisen, is that this modem is not suitable for out of the box connection to BT FFTC connections. Asus have sold a product that just isnt working
Oh here we go with the comedy.....As to your other comments regarding who has passed "BT testing", just googling for ND1436 compliance yields on the first page that EcoNet VDSL2 chipset has passed interop testing, so at least one company has deemed that UK interop testing is a good thing. (http://www.prnewswire.co.uk/news-re...trac-broadband-test-laboratory-231716931.html).
Im sure everyone cares you will not be buying a device.I've not yet bashed any of their products yet. All I have said was that I would buy this device tomorrow if it was proven stable and won't be buying it until it is.
ANYONE that claims BT test devices is a tool, they may in some way verify a device or give it a special badge of recommendation but thats it, they have nothing to do with laid down specifications as much as they may like to make their own up.As for the BT testing, I've been told (on here actually) devices were required to be approved by BT and were required to go through some sort of tests. Obviously not very close to the truth if you find it so hilarious. My bad.
NO device is tested for retailing on a telephone line as such, they are tested in a lab with equipment designed to mimic a line generating the required ITU VDSL specifications. Testing on a real life line to prove a device works would be stupid, if there were issues testing in that manner you would have to first prove its the device and not some decades old BT line you were testing it on.At least if they tested the product on a UK line, then they would have a definitive answer whether its a software or hardware issue. It would save time and effort either way if its worth attempting to fix or not. Just a suggestion.
bitNbobs, I am not going to argue with you, because oviously it is pointless. You are not really helping with your opinion aside from winding most people up with your argumentative replies. As far as I am concerned the asus is sold in the uk where sky are a major player, it is advertised as out of the box connectitivity and it has settings specifically within it for sky. If asus cannot get it to work with my isp then I think you will find it is they that are in the wrong..
Well said chriscatt. Im ignoring the obvious troll from here on in.
There's always one, of course any person looking at this thread now might be confused by what he is saying think and they are at fault by purchasing the wrong equipment.
Other manufacturers can get their products to work perfectly well with any old connection, even the cheapest. So why when one of the most expensive hardware comes along of this type is it too much to think asus, probably the largest hardware manufacturer in the world and produces something that they claim works with every type of connection, is it too much to ask they live up to that hype?
Just a quick question.
I've had it nearly a week now, and I've not had any issues.
Code:ASUSWRT DSL-AC68U_3.0.0.4 Mon Jan 12 06:52:14 UTC 2015 admin@DSL-AC68U:/tmp/home/root# cat /tmp/adsl/info_adsl.txt outDiscards=1049855 inDiscards=8279 outBytes=737255176 inBytes=584608894 outPkts=124107763 inPkts=165543628 fwVer= FwVer:5.5.1.126_B_A60901 HwVer:T14.F7_0.2 lineState=up Opmode=ITU G.993.2(VDSL2) SNRMarginDown=5.8 dB AttenDown=10.9 dB SNRMarginUp=6.0 dB AttenUp=3.0 dB DataRateDown=59705 kbps DataRateUp=19243 kbps WanListMode=1 FECDown=23964 FECUp=3303 CRCDown=1743 CRCUp=465 HECDown=0 HECUp=0 ADSLUpTime=5 days, 22:38, 36 secs ADSLActiveTime=0 min, 17 secs PowerDown=14.0 dbm PowerUp=6.9 dbm ATURID=26005443434e0000 ATUCID=b5004244434da485 AttainUp=19243 AttainDown=72188 ShowtimeStart=17 TotalStart=34 ATURANSIRev=0 ATUCANSIRev=0 ATURANSIStd=0 ATUCANSIStd=0 InterleaveDepth=1 AdslStandard=VDSL2 AdslType=ANNEX_B mtenStandard=G.dmt.bisplus (Annex L) admin@DSL-AC68U:/tmp/home/root#
I'm not sure if there's any settings I'd be better off changing there?
Also, with DLM am I fine to reboot after 5-6 days or is it better to wait until at least 7 days have passed? I'm hoping to reboot for a higher d/l and u/l rate.
OK, I've finally got through to the right people and had a lengthy discussion about the problems.
In short, they are aware of them, and are trying to correct any uncovered issues with firmware updates but right now they don't have enough data from affected users on up-to-date firmware to make improvements.
What they are hoping to do is to acquire some reports from affected users in the UK - there is a built-in feedback feature under Administration - DSL Feedback which should provide the engineers with info on the modem issues that you're having. If any of you are able to capture these issues and submit them it would be really helpful.
You should receive responses from our team - if there are issues either with the responses or you find yourself at a dead-end please let me know and I'll try to get things moving.
Slightly off topic, but going off my previous stats, would I be right in thinking my cab has G.INP? I was on InterleaveDepth=1 with FECDown=23964
FECUp=3303, meaning G.INP from what I've briefly read?
Randell i see your DataRate is at 59 if you were to use the openreach modem wouldnt you get closer to 72 DataRate.
From my experiance you have already been hit by dlm and that is why your stable, for me when i got down to 58 DataRate i would still get disconnects then i would change back to my openrach modem.
Theres a pattern:
-Me 58 DataRateDown
-You 59 DataRateDown
-Me Max attainable 71
-You Max attainable 72
Using asus as a router DataRate Down is 71 (taken from my hacked hg612)
This is dlm at work here, i think your asus modem is affected.
This is just a guess.
Submit feedback to asus see what they say.
He has no interleaving applied so likely DLM has not intervened.
The ASUS always showed a much higher attainable rate for me compared to the HG612 or Billion 8800NL - just another quirk in the way it reports figures.
My HH5 TYpe B also reports a higher AR than the Billion and HG612, so perhaps the Asus is not doing anything quirky!?
I submitted report after report though the modem and the only answers I got back made my connection even slower. So beg me for thinking I don't have much confidence in the reporting method you've suggested. I also emailed Paul and really didn't get any help so I hope in here the support will be better. Thing is, now I have the OR modem reconnected everything is running the way it was before I started using the Asus however I will keep watching here and when(?) everyone can confirm there are no longer any issues with the Asus I might consider going back to it. But it would have to be performance on par with the OR modem..OK, I've finally got through to the right people and had a lengthy discussion about the problems.
