OK, so here goes. This is the first bike I've built from scratch. In the past I've replaced parts and refurbed bikes, but this is the first build from the ground up.
Here's the frame:
It's the On-One Pompino. It's 4130 grade steel which is about as cheap as steel gets. Reynolds brand this as 520 for what it's worth. It's a single speed frame with mounts for canti/mini-v brakes and it has mudguard and rack mounts which are essential as the goal is to commute on this. Unlike grudas, I really like the blue colour, for the retro value.
Job 1, get the seatpost in. It's the cheapest aluminium seatpost that Ribble had. The seat collar is slightly scuffed so I may have to touch it up with some nail varnish
I figure I may as well get the saddle on while I'm at it, so on goes a brown Charge Spoon.
With the seatpost in it can go in the repair stand.
I'm scared of the headset, so I go for an easy win - the bottom bracket. This is a Miche square taper bottom bracket. Most single speed stuff seems to be square taper, unless you buy Dura Ace Shimano kit in which case it's Octalink. No matter, square taper will do. Miche are Italian, so it of course uses an old Campagnolo bottom bracket/cassette tool, so I had to buy one. It's huge, so I needed a massive adjustable spanner to use it. I nearly cross threaded it, which would have been a dire start.
I couldn't be bothered spending lots of money on a crown race setting tool. I rather wish I had now, as the plastic pipe bang on the floor technique failed miserably.
In the end I cut it. I'm not sure why it looks rusty in the picture, it isn't. It must have been the flash. The bike is probably gold for all I know.
After the crown race debacle, I was glad to have a proper headset press. It's massive, but it did the job. Headset cups in.
Holy mountain of spacers Batman. This is by no means permanent just yet. I'll need to get the wheels on and get the stack height right and cut the fork and then press the whole lot down properly to get it good and tight before I worry about getting the cockpit all properly set up.
After the crown race trauma, I want another easy win, so I opt for putting the chainset on. This is a Miche X-Press track chainset. It feels nice and light. The Italians are it again - this uses an 8mm allen key to faster to the bottom bracket. I had to dig out my multi tool from my saddle bag and use that to fasten it.
Second crank arm on.
Deda bars and Shimano brake levers. The brake levers are R400 which is Tiagra grade. They feel pretty comfy.
Bars on the stem.
Aaaaand time for lunch. Next I think I'll get the wheels and chain on, then the brakes, and then that'll be pretty much it. Then I can worry about getting the cockpit set up right.
