hey all, kinda new to vaping. I bought the Totally wicked hurricane and used it for about 2 weeks but all it did was make me really short of breath and weazy (like asthma). Back on the regular cigs now and chest seems to be back to normal (well as normal as any smoker can be). It was especially noticeable after sport!
Anyone else experienced this? I do really want to pack in the smoking, but really need to replace it as I have zero willpower.
snip
I get exactly the same, try Virgin Vapour stuff from:hey all, kinda new to vaping. I bought the Totally wicked hurricane and used it for about 2 weeks but all it did was make me really short of breath and weazy (like asthma).
You are swapping your batteries around when you pop them in the sigelei? There's quite a bit of a volts difference between the two batteries and from what I've been told, they should discharge evenly, even when in series.
It might be worth taking a note which one is the lower volt one and see if it keeps doing it no matter which bay of the sigelei it is in, as it could be on the way out, the one nearest to the load will age faster, but It might be just the fact your caining them.![]()
Haha, you know what, I just logged onto the forums now to report that the sigelei uses one battery then the other, I thought it used power from them both at same time.
Or etleast that's what I think its doing, because my sigelei was at 40% power, I just swapped them for the two batteries which are pictured on that charger.
And when I put them onto the charger the ones I just took out a moment ago, the battery's was at the same charge as them two were on the picture. one a lot lower than the other. so iv swapped them around also in my sigelei.
and I always put the left battery in the sigelei on the left hand side of charger, so next time I swap them out, ill know if my sigelei is using one side before the other, or if batteries are on the way out, but there brand new, well not brand new but December was it? when I got them
Also, if it is my sigelei using one side before the other, then ill start switching them around so that both batteries get used the same amount
The protank is dead, long live the Subtank.![]()
Monday vape mail...
I had a KF4 clone when they first came out and hated it but upon trying the genuine version have discovered I love it. This has happened too many times now to be a coinsidence so Im going to stick to a couple of nice genuines I can enjoy instead of a drawer full of clones that are nowhere near good enough despite being ten a penny. For me anyways,its a false economy![]()
