***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Vapemail!
First FT order here sooner than expected (ordered 27th Feb.)
Quality looks great.
Vapemail!!
Finally got rid of the cheap Chinese battery charger that came with my vamo yonks ago.
Also if your wondering why iv got tape around two of the batteries,
Its to make it easyer to see which are pair's of batteries for my sigelei.
Got two sets of efest 2500 35a's one pair with red tape, one pair with black.
And the unbanded ones are 2100 30a's for my mech mods.
I've been vaping on my new istick 50w exclusively since I've got it on saturday to test the battery life, so far with 52 hours of use.. vaping normally it's not made a dent in the battery meter, it's also feels like it's giving out the correct power too. :)
I'm got 18mg mojito in my second sub tank using a 1.2 ohm coil. The flavour is a tad too strong, I've had the bottle since before Chirstmas, and I'm normally vaping around 12mg at the moment. IMHO, the sub tank is a great tank, but unless your sub ohming and lung hitting; which I'm not crazy enough to do with 18mg, there's better tanks with more adjustable airflow and more of a range of ohms in coils for mouth to lung.
On the downside, I've got a grape flavour juice in a Kanger EMOW, and it's flavourless.. I thought it was the coil and used a new one but that's just as bad. I swear they sent me out a plain flavour, I'm going to use it to wash out my coils. :)
hey all, kinda new to vaping. I bought the Totally wicked hurricane and used it for about 2 weeks but all it did was make me really short of breath and weazy (like asthma). Back on the regular cigs now and chest seems to be back to normal (well as normal as any smoker can be :P ). It was especially noticeable after sport!
Anyone else experienced this? I do really want to pack in the smoking, but really need to replace it as I have zero willpower.
The most common cause of this is a reaction to PG, all VG juices are worth a go to see if it is PG that is the issue for you.
You might be PG intolerant, totally wicked eliquid uses 50/50 in there red label eliquids, or 80pg/20vg in there others.
Try vaping a higher VG base liquid as PG dries you out,
Im slightly pg intolerant, not bad though, but I used to be out of breath a bit when vaping say 80pg/20vg, not as bad as the old cigs but ya know, now I vape 70VG 30pg its a lot better. infact I never have a caugh or splutter ever and im never outta breath at all
You are swapping your batteries around when you pop them in the sigelei? There's quite a bit of a volts difference between the two batteries and from what I've been told, they should discharge evenly, even when in series.
It might be worth taking a note which one is the lower volt one and see if it keeps doing it no matter which bay of the sigelei it is in, as it could be on the way out, the one nearest to the load will age faster, but It might be just the fact your caining them. :)
Haha, you know what, I just logged onto the forums now to report that the sigelei uses one battery then the other, I thought it used power from them both at same time.
Or etleast that's what I think its doing, because my sigelei was at 40% power, I just swapped them for the two batteries which are pictured on that charger.
And when I put them onto the charger the ones I just took out a moment ago, the battery's was at the same charge as them two were on the picture. one a lot lower than the other. so iv swapped them around also in my sigelei.
and I always put the left battery in the sigelei on the left hand side of charger, so next time I swap them out, ill know if my sigelei is using one side before the other, or if batteries are on the way out, but there brand new, well not brand new but December was it? when I got them
Also, if it is my sigelei using one side before the other, then ill start switching them around so that both batteries get used the same amount
It might be a bit late now... normally on a serial battery mod, you should keep swapping them around between each charge so each battery has a turn at being the first battery as the first battery does more work than the second. If you keep using the same battery as the first one, it 'ages' battery quicker.
Aged batteries don't hold as much charge and discharge quicker.
Also when you use the batteries in serial your halving the mah of the battery too, so if you have two 2000 mah, you will only get the battery life of 2000 mah not 4000 mah. This is likely the reason why your battery life is quite poor as posted in a previous post. :)
I see, I didn't realise the sigelei was serial untill now haha oh well. At 0.18 ohms battery's usually go from 100% down to about 40% in hmm, about 4 hours that's when I swap em out and charge them. Also I have a mech mod on the go aswell which I toot on now and then with a different flavour in and it starts firing weak after about one hour and I swap that battery out for a fresh one but aparently it's about 3/4 full when I swap that. So I guess I'm used to vaping at 4.2v haha once it drops down to 3.5 im like meh this is fresh air!
Yeah, its a 100w so you will need to run the batteries in serial to provide enough volts to get to a 100w. you should try building higher 60w on a 0.2ohm is the same as 60w on 1ohm :) There's just less ramp up time as there's not so much kanthal to heat up.
It's cos your building so low on your mech, lol
4.2 x 0.2 = 88.2w | 3.5 x 0.2 = 61.15w | 27.05w difference
4.2 x 1 = 17.64w |3.5 x 1 = 12.5w | 5.14w difference
I'm some chargers its worth swapping the batteries around during charging as well.. shouldn't matter on high end chargers as they have individual charging meters, on cheaper ones, they charge in parallel... which should be equal, but its not always the case down to how/where its earth is.
Very impressed with these FT clones...Love the Magma, currently using a 1.1Ω single micro coil and getting clouds of so much flavour I can almost chew them. :) the SMPL mod is one of my favourites, so clean an minimalistic...I've ordered another.
Nemesis Mod, though well made, is not for me. I don't like the looks so much and I can see myself getting annoyed with the fire button mechanism. Looks ok with the Kayfun lite V2 clone which is also well made though doesn't quite have the precision of my authentic.
If everything else I've got coming (there's much, much more ;)) is this good I'll be very happy.
Yep I know.
But after using 22g, the nice and warm constant warmth of the juice is so nice.
I tried a 0.3 ohm 24g kanthal build like I used to vape and it was cold and wasn't right good compaired I couldn't vape like that again lol
Thoughts on kanger tanks anyone? Specifically the pro tank 3 or aerotank...looking for a constant cloudy, tasty vape
Using a tw oddy bdc on my 30w curve atm, and its hit and miss, more miss then anything, the atomisers are terrible, the 1.6ohm are nice to start with and die out a few days later, the 1.8ohm you either get nothing from or the taste of burning. Great waste of £30...
All my juices have arrived and steeping nicely, mainly due to the fact I am kinda in love with Vapingking Merlin.
So nice, if you like a smooth fruity menthol, try it!
The protank is dead, long live the Subtank. :D
One for the future that, as I think I would have to drop my nic levels on a sub (so I'm told?). Which isn't much help when I have around 200ml of 1.8% juice stockpiled :(
The main reason I'm looking at kanger is the atomisers are cheap, just over £1 each iirc and I can buy locally in emergencies :p
Monday vape mail...
I had a KF4 clone when they first came out and hated it but upon trying the genuine version have discovered I love it. This has happened too many times now to be a coinsidence so Im going to stick to a couple of nice genuines I can enjoy instead of a drawer full of clones that are nowhere near good enough despite being ten a penny. For me anyways,its a false economy :)
Monday vape mail...
You been hanging around safer vapours too much ;) lol
Status
