Permabanned
- 12 Sep 2013
- Knowhere
No! I need my points! Only 2 more years and I can afford an R9 260X
Same here, I'm at 19.000 so I'll get a free 260x within a year hopefully.
Only for those who upgrade every gen bru.
The majority don't buy a £400 card or whatever it is to sell on a year later at a massive loss just to have new tech.
I've had about that as well.
Your average PC gamer though buys a card slaps it in and doesn't worry about it for a few years or buy into the new card hype around every release. They upgrade once their games start struggling.
Every one of them other than the 6950 i bought weeks or days after release.
Hopefully I can keep this 295x2 till 20/16nm. Doubt any single card will match it until then.
I am really looking forward to seeing what these new cards can do in benchmarks but I will most likely skip these cards and wait it out until the next die shrink & 8Gb+ HBM cards are out.
The thing is it looks like Fiji might be the first true 4K card, IE the first card that can drive 4K like a 290/X / GTX 970/80 can 1440P.
Be that as it may it will need 8GB or its not going to be a true 4K card.
You have just forgot the Titan X.![]()
He should have said the first card at a reasonable price.![]()
+1
AMD will sell at least 5 390Xs for every one Titan X
Nvidia will sell at least 5 980Ti's for every 390X
AMD Radeon R9 390X WCE (Water-Cooled Edition)
Unlike other leaks I receive, this one arrived in PDF format. Which is quite interesting, normally no one bothers to go through all the hassle to create them. This however was in PDF, and it’s partially the reason why I decided to post it. In other words this slide got through my sniff test, which as you know is very picky these days…
The leaker claims this slide is a part of in-house presentation called ‘2015 Future of Radeon’ that will be shown next week to AIB partners.
You are probably asking the same question, why would anyone send me this? The slide does not tell us anything new that wasn’t rumored for the past few weeks. The only new bit, is the codename of the new flagship: Radeon R9 390X WCE. Maybe there are non water-cooled models? Maybe this is just internal naming for prototype. Very hard to say. I’m leaving the interpretation to you.
