Well if you can run it then that's all for the better. But the same logic applies here, it's just one step to knowing your OC is close to unconditional
Post yours
start memtestpro /t1024
exit
Quick and easy way to find out.
Leave all you voltages etc as they are and back off 2 or 3 on the multi and re run.
Actually you may only have needed to reboot to clear the memory.
I habitually reboot before running any stress test.
Anyone know why handbrakecli.exe crashes within seconds when using Realbench? It does it in the benchmark and stress test. I can leave AIDA and memtest running all day with no problems so my system can't be that unstable for it to crash in a few seconds.![]()
Nobody going for the 8 hour "real bench" max mem stress ?
Probably because realbench stress is not so easy.Possibly...when I have time. Credit to easyrider with the 'call to arms' with Aida, but so few even ran this test.
It seems no one has bothered to run Realbench anyway.
I'll have a got at this tomorrow - I've never gone past an hour before. Unrelated to this but I think some of you may be able to help -
My Cinebench score seems awfully low @ 1189. System specs are in the sig below. Any one else think it seems off for a 5930k @ 4.5Ghz?
