- 9 Jul 2013
Is this coming from your speakers or from your case (GPU) ?
From the TV speakers. The picture is ok just getting them sounds.
@AMDMatt
Did you check that FOV setting in Dying Light? Also, please check my thread (2 pages) if you have time. Thank you sir.
http://www.overclock.net/t/1547658/significantly-poor-performance-in-dying-light-on-my-3930k
@AMDMatt
Matt - is there any reason to use these drivers with xfire 7970s or am I best sticking with 14.12 omegas? I'm presuming outside of some crossfire profiles the development in drivers is now aimed at newer cards.
@AMDMatt
Are the new drivers out now matt or have they been delayed?
They are out now. It's the 15.3 betas.
anyone got a link ? Normally find them on 1st page of this thread but I can only see the 14.2 omega
They're on AMD's site and guru3d.Well, fc4 defo not smooth, even on low with vsync and triple buffering.
http://forums.guru3d.com/showthread.php?t=397877
Don't know if this has been already posted here but there you go guys... VSR and Frame Limiter to 280 series and 7xxx series cards for w8.1
Now, 7xxx was not supposed to be able to get VSR because of some (artificial?) limitations![]()
http://forums.guru3d.com/showthread.php?t=397877This is the Windows 10 driver distributed via Windows Update, now modified to work with Win 8.1.
VSR and FPS limiter are enabled (the card must support it) CCC is from 15.3 Beta to avoid issues.
Based on reports in this thread looks like VSR is working for HD7000, R7, R9 280 and possibly more so try for yourself and report back.
On R9 290 Series the resolution is unlocked up to 4K. (3840x2160)
To install and use this driver you must enable the "Test Mode" or disable the driver signature enforcement.
This driver is for advanced users only, if you do not know what you are doing stay away from it.
