- 14 Feb 2011
Err! I see the Titan X is tearing up the charts, nothing else getting a look in
Err! I see the Titan X is tearing up the charts, nothing else getting a look in![]()
Is there a reason your not running mem at +500 ?
And looks like the 5960x compliments the card well![]()
Taking it slowly - besides +500 would give me 9000, don't think so.
I initially made the mistake with my TX but no, MSI AB works off of 2 segments and you start out at 3500Mhz if I recall so upping by 500Mhz means you are at 2x4000=8000 effective.
Try testing with Heaven and look at the top right corner (it shows 3500 at stock) or on the MSI AB graphs for mem clocks.
did wonder if I had it wrong - but GPU-Z shows I am at memory of 1845 with +200, so working on that 2000 is effective 8000(x4) which means I need to add another 155 to the 200, but I get the feeling it does not quite work that way? What am I missing here?
If your not running the latest version, GPU-Z will give you incorrect readings.
He's suspended
I wouldn't worry anyway as soon as he's back I'll have beaten your score
