Question-on the third level there is a guy who is praying at a small alter,did you kill him,talk to him or both? I talked and received his gifts but I went to kill him and he nearly took me down so I ran!
Someone mentioned that with a high insight I can see the invisible arm thing that grabs you in cathedral ward. I just avoid the spot where it happens and there is a noise preceeding it to warn you anyway.
If that's all I'm missing (a few hidden non boss enemies) I am glad I used insight points to buy useful stuff
rp2000
If you're just starting, the 3 starter weapons have no requirements pal. If I remember rightly, I picked one from the messenger, went into the in game menu and equiped it, job done.
You can't do it via the inventory by the way, you press the options button, then go down to the 'Arms' squares and select the weapon from there. It's the second row of boxes IIRC.
http://techgenmag.com/wp-content/uploads/2015/02/7-improved-inventor.jpeg
I still haven't gotten past Old Yahrnam/Cathedral Ward, been absolutely hammered at work lately and I don't feel like getting home to this and getting my bottom kicked. Probably doesn't help that I refuse to continue without killing the guy at the top of the tower in Old Yahrnam.
Picked BloodBorne up last night and have played a couple of hours already, absolutely loving it. It kinda reminds me of Resi Evil 4 so far. Getting that sort of vibe from it.
I'm a little lost with the leveling system mind, is it worth going back to the lamps periodically? Or is that the whole point, is it a compromise?
Sorry, I've not played Demon Souls/Dark Souls before, so a bit of a noob. Any newbie advice would be appreciated!![]()
There's no harm in going back at all. Especially if you're struggling with certain sections. The levels are designed with shortcuts that either take you back to the lamps and/or let you bypass parts of a level - finding these (there's usually one or two before each boss) should be the main priority when exploring. It tends to go like this. Explore and die a bunch of times. Gradually learn where the enemies are and how best to beat them. Find a shortcut, go back to the hub world, level up, and carry on exploring until you find the boss. Die a bunch of times until you learn how to beat said boss. Go back to hub world and level up. Rinse and repeat![]()
Ah right cheers.... I can see im going to do well at this game!
For those that have finished the last boss, what level were you? What weapon were you using at the time?
Just interested to see the spread if any, maybe spoiler tag it as some may be sensitive to such info unsure
I was64, using a plus 10 holy blade. Probably could have leveled up more but past a certain point i stopped caring about echoes!
