. I'm looking forward to buying it now, and moving my character across from the Xbox.
I was half asleep and you would be surprised how many times I cycled through the resolution options thinking WTF, how can 1080p not be there?!?!?
Reports from other sites is that SLI scaling is exceptional.
I have seen 2x 980s running at 97-100% usage and there's a 5k screenshot doing the rounds with 4x Titan X in the high 90s.
Apparently a very good port indeed and you can expect good results with any setup.
The 980s were running 1440p with most things maxed and a solid 60fps at 1440p.
I'm not familiar with GTA, and only had a quick 5 minute look this morning - so how are you guys getting your FPS stats? Are you running the in game benchmark or is there a setting/command a la BF4/BFH where you can have it up permanently?
Do the textures look alright on medium? I had a quick look at the settings last night before bed and noticed that if I put them on high it took my VRAM usage above my card's capacity. I've got a 2GB HD7870, I'll have a proper mess about later when I get in from work , just wondered if anybody had been playing with medium textures and if so wether they looked like ass or not.![]()
What are you all using to measure Vram usage ? I hope my 980 is up to turning everything upto the max @1080p, Will be Pi$$ed if it runs out of Vram
