Whomever is taking care of the ocuk crew seems on the job.
I put an app in a little while ago and got an invite without posting here
goto http://socialclub.rockstargames.com/crew/overclockers_uk_pc
check if the request status changed to "accept invite" mine did
Mine keeps crashing due to low memory.
Can i run that game on maxed details with solid fps on Gtx 980 and 4790K?
hi guys is there a way of changing my appearance for online,can I start again.thanks
Will see if my 2GB 6950 will run it acceptably at 1680x1050, otherwise time for a new graphics card. Crew invite request sent too - gladiac.
The only thing I would have liked is the option to switch views when getting in a car. What I mean by this is that I would like to play first-person on foot and third in car. It would have been nice if it switched to that automatically
my two 7970's seam to show using 4.7 gb off gpu ram from viewing in game settings ?
is this correct and why ?
gta 5 using both's memory's off crossfire setup ?
using the latest amd profiled gta 5 drivers. was also showing that before new drivers.
Excellent. Thanks a lot mate.You could set that up to work in exactly that way on PS4 mate. Have a look in your options and there should be options to adjust default camera position for on foot and in vehicle
/edit found it
http://www.rockstargames.com/newswi...ar-game-tips-playing-with-perspective-in-gtav
"Allow Independent Camera Modes" check if the pc version has that
i fear I'll be the same - 6950 unlocked to 6970. Time for an upgrade more than likely!
Mine runs it fine with things on "High", Advanced Graphics all turned off. Just bought a 280X to hopefully get more fancy features.
