I wanna go cycling tonight but it looks like I won't be granted sign off from the Mrs.![]()
balls out of purse, on the bike, off you go
balls out of purse, on the bike, off you go![]()
That's pretty much it to be honest. One thing you'll notice is that it will shift differently under load.
I used to get my cotton ones from here:
http://www.prendas.co.uk/cycle-clothing/hats-headwear/cotton-cycling-caps.html
4 for £25 isn't bad.
My new tyres feel fantastic after the Kendas! As long as they are a bit more puncture resistant then I'm quite pleased with my budget purchase![]()
Said the single man.
but I can ride ALL I WANT
Yeah, but I'm married so I really can ride whenever I want.
Oh no, wait, I'm married. Forget everything I said.
but I can ride ALL I WANT AND EVERYTHING I WANT SO BOGOOHOHO
not sure about my Lezyne Macro Drive, anyone know if this has a storage mode ?
hey guys, just had a thought
my lights on my bike, im not going to be using them now for a long time, my knog blinder has a storage mode
thanks
ok no problem
I remember my cat eye volt 1200 had a storage mode , well pretty sure it did
thanks
I think they just discharge slower when they aren't at full capacity or it limits battery failure and a fireStoring Your Batteries
... LiPo batteries should be stored at 50% capacity. Store LiPo batteries in a charging bag or case. Do NOT store LiPo batteries discharged, as this will reduce battery performance and may lead to over-discharging if the packs are stored discharged for an extended length of time. The Traxxas EZ-Peak Plus makes it easy to store LiPos properly; just recharge the pack using Storage mode and it will charge the pack to 50% capacity.
LiPos and Low Voltage Detection
Over-discharging a LiPo battery will cause irreparable damage and may cause battery failure. To prevent over-discharging, only use Traxxas Power Cell LiPo batteries with an electronic speed control (ESC) that has a low-voltage detection system or alarm. All current Traxxas vehicles equipped with the XL-5, VXL-3s, VXL-3m and Castle Creations ESCs have Low Voltage Detection. Traxxas ESCs will show a green light to indicate Low Voltage Detection is turned on; the Castle Creations ESC will beep once for each LiPo cell it detects (for example, 4 beeps if you have installed two 2-cell packs in your model). The Castle speed control automatically activates its low-voltage detection mode when it detects it is connected to LiPo batteries. If you are uncertain about how to turn on and use Low Voltage Detection, consult your vehicle's manual or click here for some helpful support instructions. If you need further assistance, feel free to call 888-TRAXXAS. We're happy to help.
Change from £25 for two tyres and two tubes cheap enough?How budget and what are they?![]()
During winter instead of buying a CX could I put better tyres on my bike?
