- 19 Feb 2011
Godavari? What about Carrizo?
Can anyone decipher the following and set it out in laymans terms what it actually means? Lol
http://wccftech.com/amd-zen-cpu-core-block/
Basically AMD is moving to a more traditional CPU design instead of the CMT-like one they had with Bulldozer and its derivatives. Hence instead of two cores with one FPU its back to one core with one FPU.
Or could it be compilers still don't properly optimise for modules?
A "source" (read: post on a forum) indicated that they're targeting IPC between Ivy Bridge and Haswell. Of course, Skylake will be out by then.IIRC you can't optimise for modules you just optimise for threads/cores. AMD's module approach was along the same lines as intel's Hyperthreading approach, give a CPU the ability to handle more threads than it truly can. It's just AMD's was a better implementation (using worse cores).
If the new AMD CPU has ditched the failed module approach and they will be launching true octocores with Sand bridge grade IPC or higher then I'm in![]()
That's not true AMD's implementation was (and still is) much poorer in regular usage such as lightly threaded scenarios because most the processor goes unused, whereas with Hyperthreading even if you only have 4 main threads you still have 90%+ of the processor providing the grunt to execute them.
AMD's cores (modules) weren't really worse than Intel's because if you compare an FX8350 and 2500K they perform about the same speed under ideal conditions when all of the processor is being utilised (eg. encoding), the problem is that AMD chose to split their cores straight down the middle leaving them short-handed in less than ideal conditions.
It's not going to matter if Skylake's out by then if AMD are launching an 8 core with that IPC.
I really can't see it, but if they do manage that, it'd change everything over night. AMD would be literally blazing it.
