You're absolutely right. For now, the cachet of your name being in F1 is enough of a draw. What happens when that runs out?
It already has once. The manufacturer era at the start of the 00's was funded on Marketing by Association. Once that started to wear thin all the car makers jumped ship.
Renault and Mercedes said they would be gone if F1 didn't change its engine aproach, and they were key in making the decision to use V6 turbos. They ahve then stuck about since, so you must assume that its more than just branding at the moment.
Mercedes have got parts they developed for the ditched I4 engines into their road cars already (I'd have to dig back through Evo magazines to remember what though), and both Ferrari and Mercedes are throwing hybrid tech at super cars. Renault I expect are struggling to find a use, as the I4 was far more up their street. But even while RBR are throwing them under the bus they are determined to stay, so surely theres got to be something in it for them above having their name on a car that isn't even winning?
Very true, and it's pretty obvious that that's the case - otherwise the Merc unit wouldn't be so much better than the other three
But it's the energy recovery where the Merc is pulling ahead, not the actual engine at the heart of it. The FIA might as well have contracted someone to build a standard ICE and told the teams 'right, here's your engine, now go bolt energy recovery onto it'.
Would that be such a bad thing? The ERS rules are a bit of a mess however. They are open in the wrong places and restrictive in the wrong areas.
Not '95, which had a mix of V8s, V10s and the Ferrari V12 on the grid. In fact, 1995 might have had one of the most diverse grids for engine models seen in F1:
Ford - EDB V8, EDC V8, EDD V8, EDM V8, ECA Zetec-R V8
Mugen-Honda V10
Hart V8
Peugeot V10
Renault V10
Yamaha V10
Ferrari V12
Mercedes V10
I believe the first season that V10s were mandated was 1998. So, a long time but not quite 20 years. I'm still failing to see why this is a Good Thing™?
I was only 9 back in 1995 so I was struggling to remember
I'm not suggesting its a good thing, I'm just saying that those people going "the V6s are rubbish as they are too restricive" are somewhat missing the point. They miss it even further when they then suggest a return to the basically spec V8's as an alternative
Let's face it. If that Red Bull had been driven by Lewis Hamilton for those championship years instead of Vettel, then fans in this country wouldn't be complaining! And the driver must still count for a bunch otherwise the best car would win 1-2 every time.
I dunno, there are plenty of people complainign that Hamilton only won last year because he was in the Mercedes. I think F1 just needs to accept that its never going to make everyone happy.
F1 is supposed to be the pinnacle of motorsport. If it's not, then what is it for? Being the pinnacle of motorsport means having the most advanced technology. And if you limit the teams with an overly-restrictive rulebook, then you no longer have the most advanced technology.
I want to see active suspension. Ground effect. Hyper-efficient engines. I want to see more tyre manufacturers get involved and start fighting each other to produce the best tyres. I want to see someone try and rock up with a futuristic gas turbine setup (like that Jaguar C-X75 concept from a while back). I want to see development.
Has F1 ever been the pinnacle of motorsport? Its been heavily regulated to remove innovative technologies since forever. WEC (and its predecessors) have always been ahead in this area, hence the fact they are called Prototypes. F1 is more about the FIA picking a combination of rules to make a series with the fastest cars in it, more than promoting open development.
I don't know if they've made a farce of it, but they certainly haven't made enough of it. And the BS about the (lack of) noise didn't help matters.
They started on the back foot frankly embarressed about it, let all the bad press overshaddow the good, and then refuse to admit they made the right call. As I keep saying, the biggest issue is the people, not the tech.
All that aside, how about this for a "1000bhp" Formula 1:
Same engines as now, same fuel flow and fuel limit, same ~650bhp ICE output, but the MGUK output is doubled from 160bhp to 320bhp, and the ES energy output per lap doubled from 4MJ to 8MJ and the recovery unrestricted entirely. Net result, 100kg per race, 100kg/per hour, highly efficient F1 race cars with ~970bhp.
Job done?
