Can't comment on 1 and 2 but if you are using DP it could be cable quality. What type of GPU?
3. Make sure scaling is on in your GPU drivers.
4. Despite the common misconception that 1080p looks great because 1 pixel = 4, it doesn't. It still looks crap in my experience. 1440 looks much better IMHO.
I'm using a DVI to HDMI cable at the moment straight from the motherboard as this is a new build and I'm waiting for a new GPU. Do you think this could be effecting the quality of the image?
I've fixed that now, checked the maintain scaling option in Intel HD settings
So the blurry desktop and overall low quality images are the best 1080p will look on this monitor? I am disappointed in that..I was hoping 1080p would look almost as decent as a native 1080p, but this is a massive drop in quality
And you're right, 1440 looks a lot clearer for some reason!
