When you installed, I assume you did so from the Package Centre?
Can you remember if you just did an automatic install, or a manual install?
Do you still have Security Advisor set up to warn about modified system files? It is an option which can be disabled.
Was so long ago I don't really remember, but probably automatic at a guess, I'll take a look later at the security advisor bit
