- 31 Mar 2012
I have a ROG Swift and also have another 1080p secondary display connected to the card. The Swift is set to 60 Hz while on desktop yet the card still doesn't downclock and voltage remains at 1018mv constantly.
Is there a way to force it to downclock and downvolt or is it just a BIOS issue?
Well, after some fiddling about I discovered the issue is actually Precision X. When it is open, it prevents the Titan X from downclocking and undervolting (in my case anyway). MSI AB on the other hand, no problem at all, works perfectly. Only issue with the latter is you can't adjust the voltage slider so we need to wait for a new version to do that.
Bit disappointed with Precision X. A bit naff.
and say hello to swift surround
