** SAMSUNG: WARP SPEED CAPTAIN, ENGAGE!!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The new M.2 PCI-E SSD's are getting extremely fast as long as you have a motherboard to support the technology. Now in stock at OcUK are the new SM951 M.2 SSD's:
Samsung SM951 128GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV128HDGM-00000) @ £89.99 inc VAT
The SM951 boasts outstanding performance, supporting both PCIe 3.0 and PCIe 2.0 interfaces. They can read and write sequentially at 1,600 MB/s (megabytes per second) and 1,350 MB/s respectively based on PCIe 2.0. This performance level is approximately three times faster than that of the latest SSD with a SATA interface and about 30 percent faster than that of the Samsung XP941, its predecessor. In addition, the new SSD's random read and write speeds reach up to 130,000 and 85,000 IOPS (inputs / outputs per second) respectively.
For ultra-slim notebooks and workstations wanting to adopt the PCIe 3.0 interface, the SM951 can read and write sequentially at 2,150 MB/s and 1,550 MB/s respectively, which would provide approximately four times faster sequential reading performance compared to current SATA SSDs. With a PCIe 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 MB/s per watt for sequential reading and 250 MB/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the XP941 SSD.
In addition, the SM951 is the first SSD to adopt the L1.2 low power standby mode (which allows all high-speed circuits to be turned off when a PC is sleeping or in hibernation) as defined by PCI-SIG (the PCIe standards body). By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced – to under 2mW, about a 97 percent decrease from the 50mW consumed using a L1 state.
Samsung's SM951 comes in the M.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" SSD. Also, it weighs approximately six grammes. The drive's compactness is well suited for most notebook PC designs, freeing up space for other components including the battery. The SM951 lineup consists of 512, 256 and 128 GB SSDs.
PLease Note. Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot
- MLC NAND
- Read Speed: 2000MB/s
- Write Speed: 600MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £89.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV256HDGL-00000) @ £155.99 inc VAT
PLease Note.</b> Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- MLC NAND
- Read Speed: 2150MB/s
- Write Speed: 1200MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £155.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV512HDGL-00000) @ £299.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1500MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £299.99 inc VAT.
ORDER NOW
SSD's getting insanely fast!!!!
So as long as your MB has a M.2 slot and has PCI-E at x 4 lanes it will work? A la' MSI Gaming 7? or are you going to make me buy a new MB as well :P
Yeah, the guy who set them up did it wrong. :o
Shall fix it.
Fire him and give me his job instead, I'd have never made such a mistake.
i'll have to wait for new pc, unless anyone knows those m.2 pcie adapator riser cards work in a socket 1366 mobo
M.2 slot yes, but make sure its a real M.2 PCI-E slot and not an M.2 SATA slot, the difference is huge. ;)
Or of course PCI-E and fine, but I don't think these come with a PCI-E card as they are OEM.
I believe PCI-E adapter card works fine as they are true M.2 interface, it must be M.2 PCI-E interface and not M.2 SATA interface otherwise you are limited to SATA maximum speeds.
Wow fantastic! Saw them for sale on one tiny UK retailer a while back for a premium price, glad to see them finally hitting larger retailers like yourselves! Might just have to order one soon! My Asus X99 Deluxe is ready!
They've being collecting dust in our warehouse for a couple of weeks unfortunately, spotted them this morning. :)
Boo! haha
Will check the balance after today and will consider getting an order in, been looking forward to these since I first saw them :)
EDIT - Is there any word on you guys stocking the NVME versions of these?
Would one of these work at full speed in my motherboard?
Its an Asus Z97i-plus. I've got a 980 in the pci express slot already but the m2 slot is spare.
Its an Asus Z97i-plus. I've got a 980 in the pci express shot already but the m2 slot is spare.
According to the Asus site, your in the same boat as me, your M.2 slot although pcie compliant, is Gen2 (x2) and not Gen3 (x4). Most Z97's are in a similar boat when it comes to the M.2 slot.
So it would work no problems, just it won't be running at its fastest possible speed (Drive) but it will be running at the fastest the slot allows, which is still far higher then if u used a standard sata3 M.2 drive.
these are the NVME versions.
Hence this "- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot"
This means that it uses 4 x PCI-E lanes, which is NVME technology.
