- 17 Aug 2003
- Woburn Sand Dunes
mmmm tasty
Can you boot from one with a pcie riser.......?
these are the NVME versions.
Hence this "- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot"
This means that it uses 4 x PCI-E lanes, which is NVME technology.
According to the Asus site, your in the same boat as me, your M.2 slot although pcie compliant, is Gen2 (x2) and not Gen3 (x4). Most Z97's are in a similar boat when it comes to the M.2 slot.
So it would work no problems, just it won't be running at its fastest possible speed (Drive) but it will be running at the fastest the slot allows, which is still far higher then if u used a standard sata3 M.2 drive.
Thats a bummer then. Its a bit misleading on the motherboards info page where it states upto 10Gbit/s data-transfer speeds when this drive needs upto 8Gbit/s and wont work at full speed due to the pcie lanes
Will it be noticeable speed increase over a normal sata ssd when using it as a os drive? I don't move files around much.
According to the manufacturers code on the OCUK website, they are the AHCI, not the NVME drives.
The NVME variant is the proper quick one.
MZHPV256HDGL-00000 - AHCI
MZVPV256HDGL-00000 - NVMe
Youe site has the part code for the AHCI variant, but with those stats you've just quoted they have to be the NVMe variant which is the PCIE x4 one.
At any rate, I've ordered a 256 so I'm happy!
Fascinating
Don't hold me to this though, could be a complete miss-communication, but keep an eye on what Samsung are doing.![]()
Cool, will do thanks for the heads up.
At any rate it's going to be at least twice as fast as my plextor, so it's all good.![]()
OcUK not selling any adaptors to fit one of these into and then take up a PCIe slot?
