Mountain Biking
One goes on the L and the other goes on the R. Similar to your hands :D
Yeah... but I mean why upside down? I think I've tried both, and preferred it upside down - is that what you meant? It's just in a more natural sort of position, having a RH button on the left?
Yea, if you had it upside down, then it was a RH lever, that's put on the left hand side of your bars.
I don't get why they even make them so they go above the bar, don't think I'd be able to reach it naturally if I had mine above it like it was designed to. Before I knew it was a trick, and got my first dropper...it didn't even cross my mind that I mounted my RH lever "incorrectly" under the left. The proper way just seemed far too unnatural.
also when you flip your bike upside down they get broken / ripped off if you put them on the correct way
= under bar mounted FTW!
ordered some brendog pedals for colourmatching too :D
just need the slick graphics for my pike to make it stealthyy
I might be up for that, will let you know what the rest are up to... think Shaun wants to go try Tidworth.
ps: You're not welcome to come along, if your username is named after that boyband?
Begbie: Jono is my height (177cm ish), think you're about 183cm (6ft) odd ? That would make you 150mm territory.
Begbie, any comment on this?
I *think* 125mm will be ok for me; my legs are not very long at all... But that said, I don't want to be annoyed at having one that's too short :)
Coal Not Dole
Wibbly Wobbly
Vicious Valley
Sixtapod
Theres loads more on there I uploaded but I dont know how to edit or put music and stuff in.
Back brake sounds so awesome due to fork juice
Speaking of armpump I'm thinking of getting some ergon grips as standard grips are to small - any experience and where could i buy some online?
Claim benefits and ride all day!
Merthyr was on a tv show called skint. I know tv makes things look how they want you to see it and it looked terrible.
Offset bushes fitted and chainguide/tensioner back on after narrow wide clutchness let me down 3 times.
Kevlar pads to be ordered and i want some monarch volume spacers if someones got some knocking around. Far too linear on fully open.
Merthyr is the biggest crap hole ive ever been too and I live 20 mins away from there :p
But trust me on this, you live close to BPW and you will get fed up of it. I aint been for months nor do I want to, especially what they charge these days!
