Humbug's Pre-Alpha Benchmark Testing
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I need this testing on different systems, its a small map with a lot of Collision Physics Grass, its going to be very hard on the CPU, but i also need to know how different GPU's deal with the amount of Polygons
Download the 5 Zip files, extract them and use the .exe to install. Use 7zip, Winrar doesn't like them.
https://drive.google.com/folderview...9wNjVDMkt0Z3l1ai1wa2lGN29jQVlueW8&usp=sharing
Some of the menu items are not yet debugged, i have marked in red the ones not to use and ones you can use in green, see spoiler below
To run the Benchmark simply load up the map as normal and use Shift + Print-Screen keyboard shortcuts, please don't hit anyother keys, let the Benchmark run to completion, when its done it will take you back to the main menu, simply exit the game.
The results should be in C:\Humbug\TestResults there is a text file named timedemo
Thats what i need you to paste here, it should look like this.
Please add you system specs and what Game IQ setting you used, thanks :)
TimeDemo Play Started ,Level=Humbug_Playground_Test (Total Frames: 8659, Recorded Time: 170.22s)
Run Finished.
Play Time: 170.46s, Average FPS: 50.80
Min FPS: 13.20 at frame 933, Max FPS: 161.55 at frame 7349
Average Tri/Sec: 8516036, Tri/Frame: 167644
Recorded/Played Tris ratio: 1.08
Memory Usage: WorkingSet=627Mb, PageFile=838Mb, PageFaults=1278485
AutoTest Play Ended, (1 Runs Performed)
If you want to look around in the map thats fine, please do, shoot at the Grass, see how it behaves.... if you don't like screen tearing and want V-Sync here is how.
Go to C:\Humbug and find the System file, open it up, where it says r_VSync=0 change 0 to 1 so it looks like this r_VSync=1
Thanks and feel free to give me any feedback :)
Downloading now, but I've got to go out in a few mins. Ill give it a go when I get back.
Results:
Run Finished.
Play Time: 223.80s, Average FPS: 38.69
Min FPS: 17.42 at frame 933, Max FPS: 145.99 at frame 3660
Average Tri/Sec: -464577, Tri/Frame: -12007
Recorded/Played Tris ratio: -15.08
Memory Usage: WorkingSet=740Mb, PageFile=2509Mb, PageFaults=1264363
System / IQ:
Intel® Core i5-2500K @ 4.5 GHz
MSI GeForce GTX 780 Twin Frozr OC Gaming 3GB
Gigabyte Z68P-DS3
8GB DDR3 1333 Mhz 9-9-9-24
"Very High" Quality
2560 x 1080 resolution
Fullscreen
Ok ran it at 2560x1440 on Samsung (S32D850T)
Results:
Run Finished.
Play Time: 130.27s, Average FPS: 66.47
Min FPS: 24.26 at frame 970, Max FPS: 190.48 at frame 2
Average Tri/Sec: 12235842, Tri/Frame: 184080
Recorded/Played Tris ratio: 0.98
Memory Usage: WorkingSet=713Mb, PageFile=2512Mb, PageFaults=1224065
System:
Intel® Core i7-4790K @ 4.8 GHz
Gigabyte Titan X @ 1377/2003
MSI Gaming 9 AC
16GB DDR3 2400Mhz
"Very High" Quality
2560 x 1440 resolution
Fullscreen
telling me the zip files are corrupt :(
On trying to extract them?
It should be 5 files, Playground.zip001 to 005, extract them into a folder starting with 001, what you should end up with is ten 500MB .pak files and one .exe
I used 7zip to compress them in Windows zip format, try using 7zip
Run Finished.
Play Time: 141.34s, Average FPS: 61.27
Min FPS: 35.77 at frame 1877, Max FPS: 221.24 at frame 2
Average Tri/Sec: 11253351, Tri/Frame: 183683
Recorded/Played Tris ratio: 0.99
Memory Usage: WorkingSet=711Mb, PageFile=4111Mb, PageFaults=1290101
GPU (1x) at 1253MHz CPU @ 4.2 (HT off)
Specs in sig
