[TW]Fox;28129467 said:
This is what I mean about people not really ‘getting’ it. Why would you have it set to 25c? You wouldn’t. It isn’t going to make it any more toasty warm in winter nor is it going to heat up any quicker when its cold. It’s a main thermostat setting – you don’t constantly adjust your home central heating thermostat do you? You don’t set your home thermostat to 25c do you? You might manually turn a radiator up from time to time but that’s not the same thing as adjusting the main system attempt randomly every time your mood changes.
I do "get it", I understand exactly what the setting is. I don't bump it up to 25c for quicker warming, nor reduce it to 16c for quicker cooling. What I'm saying is, it's perfectly logical for the temperature you are comfortable with to be different occasionally.
A house thermostat isn't really a fair comparison. Of course I don't constantly adjust that. But generally, I'm wearing the same sort of clothing in my house all the time. Whereas if I get into my car in the winter, I'll probably still be wearing a heavy winter coat or jumper. Whilst 21c might be a nice comfortable temperature the majority of the time, wearing stuff like that wouldn't be comfortable in that sort of temperature for the whole journey, so I might nudge it down - easier than trying to remove clothing while driving.
21c (+/- 1c) is generally recognised as the optimal ambient temperature for people. So, the system stays set to this and maintains that, if you get in a freezing cold car it’ll heat the car up and be toasty and warm on the way to doing that and then gradually reduce the vent temp as it approaches it. So you get the toasty warm effect in winter. If it’s hot outside and a sauna inside it’ll cool the car with chilled air in exactly the same way. It even adjusts for the effect of solar gain. It just works.
Obviously sometimes we want to deviate from this – you’ve been for a run and you are hot, you want cold air. You don’t need to change it to 16c to get this, you can just over-ride the main vent with only cold air. Bingo – blast of cold air. Ditto if you want it a bit hotter than normal or something.
I think this is where we might be arguing different points. At no point have I suggested adjusting the climate control for such short term gain. I don't continually adjust the temperature to influence the actual temperature at the vent. I just set it to a comfortable ambient temperature. Generally this is 22C, but as I said above, this might change depending on what I'm wearing.
Continually changing the temp dial just seems to defeat the point of AUTOMATIC climate control, plus it isn’t even that efficient. Unless you dramatically change it, adjusting from 21c to 19c isn’t going to suddenly blast you with ice cold air, whereas the vent control allows you to do that if you wish.
As above. I'm not continually changing it to get the vent temperature to change, but I do see your advantage claimed with being able to do that individually.
Obviously this might differ in a more basic setup but in a decent system you set it up once – to your preferences – and forget about it. It takes care of everything else automatically, if your window fogs up the fogging sensor detects this and diverts air over the screen without you needing to intervene. If the sun is making it feel hotter inside than usual it detects this and blows colder air, etc etc.
This is how I work mine – I set everything to auto, 21c and then never need to touch the climate panel ever again.
I do the same. It's set to 22C and rarely touched. It blows colder when the sun is stronger. My simple point was that 22C is not always the perfect ambient temperature for what I'm wearing. I'm happy to nudge it down a degree or two in the winter when I'm wearing heavier clothes - which is why I was querying the individual vent control; I can see the advantage for getting a very quick fix of warm or cold air from the vents, but ultimately I'm going to want the ambient temperature adjusted slightly anyway.
It’s actually frustrating to have to constantly fiddle with the main temp setting in cars with a less useful system installed.
Yet you're happy to fiddle with the individual vent temperatures?
